Results 1 to 10 of 10
Thread: GU Aircon fan switch fault
    Jan 2014
    Sunshine Coast
    Cool GU Aircon fan switch fault
    The fan for my aircon stopped working on the 1 setting a few weeks ago and now will only work on setting 4. Can anyone advise if this is likely to be a faulty switch or something else. If it is a switch, where to get one and are they difficult to change?
    99% chance it is the ballast resistor pack for the fan motor cobber and not the switch
    175 Post(s)
    100% the resistor is gone. On setting 4 the resistor is by-passed so it's as if it isn't there. Cheap part, but a PITA to replace.
    Good luck. BY the way welcome to the forum!
    Jan 2014
    Sunshine Coast
    Graymare
    Thanks for responses guys. Does this mean removing the Fan Motor? Any clues on this? Or do I need to take this to an auto electrician?
    Legendary happygu's Avatar
    Here you go Graymare....
    http://www.patrolapart.com.au/produc...u-heater-fan-2
    The page tells you where to find it too....
    Mic
  7. The Following 2 Users Say Thank You to happygu For This Useful Post:
    Graymare (8th January 2014), my third 256 (11th January 2014)
    Jan 2014
    Sunshine Coast
    Smile
    Thanks mate, really appreciate your help.
  9. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The fan resistor sits behind the glove box next to the interior fan motor
    It is the brown plug bottom right of photo. You can remove it with out removing the glovebox but it much easier with the glovebox removed and it's only 6 screws to get the glovebox out.
    It would also be a good idea to remove the interior fan motor (black cylinder in centre of photo) and make sure the fan spins freely by hand. If it doesn't this can cause the resistor to burn out.
    Also the resistor need to be cooled by air from the interior fan motor so don't plug the new one in without it being screwed back into the housing.
  10. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    my third 256 (11th January 2014), NP99 (9th January 2014)
  11. #8
    Jan 2014
    Sunshine Coast
    Well done guys. I got the part through Patrolapart for $30 and fitted it in 10 mins and it all works well. Thanks for your advice, hope I can return the favour sometime.
  12. #9
    Oct 2017
    hi Graymare,
    I have the same problem. what is the part that you had to purchase? would you have a part number? i know this is 5 years since your post lol.
  13. #10
    Dec 2019
    Western Sydney, NSW.
    My Fan Speed Resistor Pack went on me a week or so ago.
    New eBay Ballast Resistor Pack arrived today, and in true eBay fashion only the 4th Speed Setting only working.
    Read here on the forum about another member bridging the burnt out resistor on the circuit board, so thought what the hell . . . out with the solder iron and the temporary Mod to Original Resistor Pack . . . a small wire bridge where the blown resistor was . . . simple . . . and now all four speed settings working.
    I've ordered another Resistor Pack, so the temporary fix should hopefully do the the job till the other Resistor Pack arrives.Inked84150335_1043128889398406_5335487337512042496_n_LI.jpg
    Grant
    Penrith Region
    Sydney NSW.
