6th January 2014, 04:39 PM
surging symptoms
Hi all, latest problem is as follows, any help would be great.
start vehicle and drive for 10mins all good, then pull away and it surges continually until foot is off accelerator and then re applied. All good until foot backs off,then depresses again and it starts to surge again. This happens on both gas and fuel just spent a few thousand sorting all the issues out before Crimbo and its been fine on long trips.
6th January 2014 04:39 PM
6th January 2014, 05:17 PM
Sounds electrical. My guess would be failing alternator and/or battery.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
16th January 2014, 04:00 PM
If trouble is on both fuels it could a vacuum leak that opens as the engine heats up. Or it could be an ignition component that is failing when it gets warm. I've had a coil do that and also a condenser which would break down after 10 - 15 minutes. Remind me which engine you have, Pezzer.
4th March 2014, 12:47 PM
check the timing and coil mate
