Results 1 to 8 of 8
Thread: Rear spring hanger guard
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    If you have a leafy and follow them coily trucks you may have smashed your spring hangers. Mine got bent real bad and needed some encouraging back into shape. Kept looking for bigger hammers.
    So I made these...
    Last edited by MudRunnerTD; 1st January 2014 at 09:21 PM. Reason: Fixed title for you
    Macca
    Most will fab from some 6mm flat but the same idea, like a mini slider good job
  4. The Following User Says Thank You to threedogs For This Useful Post:
    macca (1st January 2014)
  5. #3
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    very simple but great idea, nice work
    GQ Snorkle Lockers front n rear
  6. The Following User Says Thank You to 89gqpatrol4x4 For This Useful Post:
  7. #4
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Bloody hell, never seen anything like it. Thought I had come up with something new!!! Bugger.
    Macca
  8. #5
    Ballarat, Vic
    174 Post(s)
    Feel free to make a couple more & send’em down my way Macca.
    A Nomadic Life (Blog)
  9. #6
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Cuppa, I'm gunna have to find someone else's tub of scrap steel. Mines looking sort of empty.
    If its not too much trouble can a mod fix my spelling mistake please.
    Macca
  10. #7
    330 Post(s)
    Fixed the title for your Macca, how did you attach them?? Good idea though.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #8
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Thanks for that Muddy.
    They are held on by a single M12mm HT bolt through the bottom of the chassis, the nut has a bit of wire welded to it to hold it in place via that hole in the chassis side. The wire has broken off the RHS one.
    2 10mm 75mm plates welded make the top bit and a large hole is drilled in the lower piece to fit the bolt and socket. The lowest piece with the folded sides (5 or 6mm) covers the lot and is held in place with M8 HT countersunk bolts.
    The weight will be on the front against the chassis and both sides of the hanger. Have seen scratches on them but no real hard test has been done yet.
    Macca
