Results 1 to 10 of 12
Thread: Convert Tb42e to turbo diesel with efi ?
    Jun 2013
    Warrion, Victoria
    Hi just wondering if anyone has ever try'd to convert the efi petrol motor to a diesel motor with turbo and running the efi system off the petrol on it ?
    Expert james008's Avatar
    Nov 2013
    Never tried, but the EFI setup from a petrol motor won't suit a diesel as they are completely different motors.
    Owned nothing but SWB Patrols
    '84 Red MK SD33T SWB, 31" A/T's, bullbar, spotties
    '86 Silver MK L28 SWB, 31" muddies, bullbar, steel canopy
    '86 White MK SD33T SWB, 31" A/T's, ARB bullbar, spotties, steel canopy
    '85 Silver MK SD33 SWB 31" A/T's, bullbar, light bar, 2" lift, snorkel
    Jan 2013
    No. Just no.
    Jun 2013
    Warrion, Victoria
    if one was to make an adapter plate to bolt the efi intake to the diesel head theorietically it could work or get a custom billet head with the intake schematics of the efi on the diesel head
    How do you get the parameters/sensors from the TD engine that the EFI Computer requires?
    Where do you get suitable electronic diesel injectors from?
    I can't begine to imagine the cost of the engineering to get the manifold to fit
    How would you program the ECU?
    What possible engineering benefit is there in retaining the EFI intake manifold in the first place?
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Petrol is injected into the cylinder at 40psi. Anyone know what diesel is injected at? I dont know exactly what the figure is but it's much higher than 40psi.
  8. #7
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Up around 200 psi I think
  9. #8
    Jan 2013
    Indirect diesels 1500psi +. Direct injection diesels 5000psi +. Common rail up to 45000psi.
    Theres just so many things. Compression ratio (the head). Injecting diesel in an intake runner wont work at all. Diesel is injected at the top of compression stroke. Petrol is injected on the intake stroke.
    Tb42 are chain driven cam. Timing cover totally different. No squirters. Pistons would not cope. No where to put injector pump. The list is endless.
  10. The Following 2 Users Say Thank You to Dales300exc For This Useful Post:
    BigRAWesty (5th January 2014), the evil twin (5th January 2014)
  11. #9
    43 Post(s)
    Crack pressure of 1600 - 1800 psi ...
    Marginaly different.
    Would be far simpler to just swap engines.
    Compression is different, but unsure if that's controlled by the head..
    So possible different stroke length.
    Is the firing order the same??
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
  13. #10
    Quote Originally Posted by Parksy View Post
    Indirect diesel injection is over 1000 Psi up to about 2000 Psi
    Direct injection significantly higher
    Common Rail injection pressure is 25,000 to 40,000 Psi depending whose system
    Edit... (Sorry guys... didn't mean to replicate info... we were all typing together)
  14. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (5th January 2014), Dales300exc (5th January 2014)
