Results 1 to 10 of 10
Thread: GME TX6200 parts and advice required
    Hi all again I have a GME tx6200 UHF hand held that requires a belt clip. any idea where I would get one .
    Plus has anyone used the throat voice activating mic, or which is the preferred method.
    I aslo have an Icom Joey for track work, small and compact I love it..
    I'll take any info I can get as going on a trip soon
    Its ok so far I've found a belt clip and a leather case for it, now just need to know if the PTT is for this model.
    Apr 2011
    Melton
    Three dogs, send GME an email re the mic - I have had a quick look at their web site, could not see a throat mic listed
    The web site is http://www.gme.net.au/
    I have tested troat mics in the pass, found that the need to be tight - ie like a priests collor to work, also tested skull mics - need to be tight.
    Try MCKAY's they might be able to help with an after market unit
    Aug 2010
    adelaide
    OH LEATHER IS NICE
    Thanks found a head set for it plus an upgraded antenna.
    brisbane
    I've got a 40 ch one and I just clip it on my pants and have a remote mike/ speaker that I use.
  8. #7
    Do you just clip Mic to shoulder ???
    http://www.ebay.com.au/itm/370831481...84.m1423.l2649
    Would this be handy if 4x4ing
  9. #8
    Apr 2011
    Melton
    A portable with a speaker mic is handy if you are directing a vehicle over an obstacle.
    I would stick to a vehicle mounted radio for convoy driving.
    Even though the portable has the same spec as a mobil (and without a external antenna), the unit will have reduced range compared to the mobile due to placement of the antenna. Basically the unit is insie the vehicle next to a lump of meat (you)
    I have done a lot of work in regards to in building portable coverage and what levels are need for it to work.
  10. #9
    brisbane
    Yea I just clip it to my shirt.
    I only use it for when I'm out of the car as I once used it as my main uhf ( using the trickle charge/ external antenna kit) but it wouldn't last a full day of wheeling.
  11. #10
    http://www.ebay.com.au/itm/261118251...84.m1423.l2649
    Try this shop for shoulder mic and headsets, cheap too
