28th December 2013, 04:18 PM
timing belt
Hi everyone, I have a 92 ford maverick 4.2 petrol carby. I was wondering how much work this there to get to the timing belt to change it and how often does it need changing. I have had this vehicle for over two years now and its done about 285k and I dont think it has been changed or anything. Thanks for your help guys
28th December 2013 04:18 PM
28th December 2013, 04:59 PM
28th December 2013, 05:00 PM
Is it a chain or belt on the 4.2?
1999 GU 4500 dual fuel
Il dado è tratto
28th December 2013, 05:01 PM
29th December 2013, 10:36 AM
29th December 2013, 10:51 AM
Dribble Master
Chain on the TB42, gears on the TD42
growler2058 (29th December 2013)
29th December 2013, 11:53 AM
Hi growler2058 how do you adjust that.
I have run out of ideas what could be causing the car to back fire thought the carby and though the exhaust. I have tried changing the piontsand adjusting the timing and it still does it.
29th December 2013, 12:03 PM
My manual lists these items for a backfiring carby engine. Faulty Exhaust Gas Recycling valve (EGR), vacuum leak, valve clearances, carby fuel float level, stuck valve, or faulty valve spring and Thermostatic air system faulty and of course engine timing.
29th December 2013, 12:35 PM
SPAMINATOR
Clunk
Being useful again clunk tutt tutt tutt
29th December 2013, 01:01 PM
Hi mudnut I will check all those areas out.
The other thing is that its an intermitten problem
