Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Is this tablet ok
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Yeah as clunk mentioned 3G is for net but the cheaper tablets and iPads didn't have the built in GPS receiver which is what I bought not realising.
    Huge mistake!!!
    most cheap ones do have gps, mine did and is a 100buck Chinese piece of crap, my gps setting was turned of so at first I thought mine didn't have gps because it didn't work with the you4wd app and the crappy manual mentioned nothing about gps wasn't until playing with settings that I found one for gps and it was switched off.
    .......... TPC's Avatar
    63 Post(s)
    I have a Asus Tab and have loaded the android version of oziexplorer and found it not very good, it is not the same as oziexplorer on a PC.
  4. The Following User Says Thank You to TPC For This Useful Post:
    PMC (2nd January 2014)
  5. #13
    Apr 2011
    Melton
    I have a galaxy TAB2 7".
    The unit has internal GPS, takes up a 32 Gb card
    A new galaxy TAB3 7" are around $225, faster, internal GPS, more storage etc.
    I'm running android Oziexplorer and very happy with it, yes its cut don from the PC version, but it does the JOB. I believe the tab3's come with a Turn by Turn GPS apps as well.
    I used a RAM Mount - (designed for the Samsung) to properly mount the unit - I have posted else where about the ram mount
    I used the tab at home to acess the internet via wifi. I have also just purchased a TELSTRA hot spot that I can take on trips tyo use with my phines and the tablet
  6. The Following User Says Thank You to GQ TANK For This Useful Post:
  7. #14
    Hardcore
    Coffs Harbour
    Quote Originally Posted by GQ TANK View Post
    G'evening GQ tank,
    Will you be bringing your set-up with on Saturdays B/Q meet & greet in Geelong? I would like to get some ideas for my Patrol!
    Regards,
    RLI
    The halls been rented the bands been paid, time to see you dance!
  8. #15
    Apr 2011
    Melton
    Im not sure if I will bring the GQ, as im planning on changing the front diff -
    Have a look at this thread I posted - photos and all
    http://www.nissanpatrol.com.au/forum...tablet-in-a-GQ
