2nd January 2014, 03:12 PM
#51
Hate to be bearer of bad news but white/grey smoke would mean a stuffed turbo.
Maybe some others could confirm this
dirtygu (2nd January 2014)
2nd January 2014 03:12 PM
2nd January 2014, 03:30 PM
#52
Would that b why I still have boost but no power
2nd January 2014, 03:58 PM
#53
Are you able to get your fingers in there to turn it and see if it feels nice and free.
2nd January 2014, 07:06 PM
#54
Ok will do ill give it a try
3rd January 2014, 02:40 AM
#55
Turbo seams fine
3rd January 2014, 08:20 AM
#56
HHHmmmmm I'm out of ideas,. when mine was going into limp mode it kept throwing up the error code
for the Crank position sensor. PITA to remove. Is yours throwing up ant error codes??
3rd January 2014, 08:27 AM
#57
dirtygu
Ok have had a closer look at the car it has a small amount of white grey smoke what could that be also still have the non power over 3k rpm
White smoke = water burning in combustion chamber .. possible cracked head ...or blown head gasket... have u overheated before these problems arose...
NO HILL TO STEEP
NO RUT TO DEEP
The Following User Says Thank You to PATROL KING For This Useful Post:
threedogs (3rd January 2014)
4th January 2014, 11:47 AM
#58
Yeah it did over heat but not that bad got just over half would explain where my coolant has gone but thats been leaking somewhere for a while and I just did a new head and gasket
4th January 2014, 02:47 PM
#59
you are leaking coolant and have for a while and you don't know where its going is that right ??
