24th December 2013, 10:02 PM
knocking in the front end
I have a gq patrol TD4.2 I have a knocking noise in the front end when driving it seems to get worse when turning
I have checked wheel bearings, lower control arm bushies, pan hard rod bushies and checked the tension on the nuts and bolts under the car
I haven't check Radius Arm bushies (ones on the chasse) or king pin bearings or cv joints
plz help
24th December 2013 10:02 PM
7th January 2014, 08:20 PM
Patrol Guru
check the chassis bolts to the body, it not uncommon for these to loosen fractionally & it will clunk when turning or going up driveways, & the shocks sometimes loosen
2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
8th January 2014, 11:55 AM
Legendary
1999 GU 4500 dual fuel
Il dado è tratto
8th January 2014, 12:25 PM
X 2 on the CVs as its only when turning, but they would be more a click click sound
The Following User Says Thank You to threedogs For This Useful Post:
