25th December 2013, 02:28 PM
When your trying to start it hot does the engine seem like it is turning over fast enough, at the same speed as when it's cold?. Or does it seem slower?
What voltage does the battery drop down to during cranking? both hot and cold?
afatboy (25th December 2013)
25th December 2013 02:28 PM
25th December 2013, 03:14 PM
Yendor
seems to be cranking over at the same speed as normal.
25th December 2013, 06:28 PM
Sounds like something is not re setting when hot. can you swap the AC relay with the ecm relay and try, probably wrong but all I have,
Yendor is the man, did you check the brake light switch??
26th December 2013, 12:13 PM
If you're spraying start ya bastard into the engine while hot and it still doesn't want to even show signs of life, then it does sound like an ignition problem. You said you have spark, was this even when hot? My first guess is to replace your spark plugs, might have the wrong heat range plug installed.
The Following User Says Thank You to Parksy For This Useful Post:
afatboy (26th December 2013)
31st January 2018, 01:00 AM
i currently have the exact same problem and am hoping that you guys may remember why it has happened... so confusing
31st January 2018, 01:58 AM
zobee
hello......
31st January 2018, 06:38 PM
#17
afatboy
TB42 efi. Starts fine when cold. Once up to normal running temp you can't turn it off or it won't start again. Will turn over no problems, you can smell it getting fuel, plenty spark from the coil and from dizzy to leads. Just won't fire. I was convinced it was the immobilizer, so I removed it. Still no success. Any ideas?
Plethora of reasons that can produced the above scenario. Always start with electrical side of the story as a rule of thumb.
Chekc the spark when hot, which includes the spark out of the leads as well as each spark plug. After ruling out the ignition system, then you can check the sensor like MAF etc and then move onto fuel pressure etc. Since the problem happens after warm up, tests should be done in the same condition.
2nd February 2021, 10:20 PM
#18
Hey guys, sorry did any of you guys end up working this issue out? I know a guy having this exact issue.
2nd February 2021, 11:09 PM
#19
Righto, I'll have a crack of figuring this out. Believe it or not, the ECU gets it's earth from the top of the engine, around the throttle body. There's two earth wires/connections adjacent to each other connected to 6mm bolts (from memory). If these connections become poor - and heat can turn them from just passable to problems - the lights and starter will work fine, but the car will absolutely not start. Check these connections and clean them up. May or may not be the problem, but it was on my old girl 10 years or so ago and after fixing this she didn't miss a beat and is still happily running today.
The Following User Says Thank You to ReefMagnet For This Useful Post:
10th February 2021, 06:57 AM
#20
ReefMagnet
Cheers reef, he gave that a go. They were a pretty poor connection but didn’t seem to solve it unfortunately
