20th February 2013, 04:55 PM
#71
Ok, the old is getting pretty bad. Nearly to the point of its coming off the road now..
I'm looking for parts but have noticed I have a solid steering rod, non adjustable...
First question, can just the rod end ball links be replaced?
If not, has anyone modded there steering rod to adapt to removable rod ends? If so how did you do it.
And finally, if I am to mod it, does the steering rod use the same rod ends as the drag rod?
Fyi, its a 91 gq coiled wagon.
20th February 2013 04:55 PM
21st July 2013, 04:10 AM
#72
Control arm bushes done?
Sent from my GT-I9305T using Motorculture mobile app
'92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
Lukey 2.5" Performance Exhaust with Extractors, snorkel
Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
21st July 2013, 09:38 AM
#73
gazoo
Hi all can someone help me ive just fitted new rims and tyres to my GQ and now when i get to 80kph the steering shakes that bad i have a job to hold it i took it back and they checked it al out and said that they all balanced up good i watched them when they did it. It did have a slite shake befor with my old rim witch were alloys but not as bad as it is now with steel one (sunraisers
I haven't read the whole thread so this may have been covered:
I mate of mine recently bought a gu ute with sunraisers. When he reached 80-90kmh he would get a nasty wheel wobble. He checked the bearings and all bushes (he's a mechanic) but couldn't locate the cause. He decided to buy the original steel gu rims and get them powder coated black. Low and behold after putting them on the wobble had gone.
The sunraisers were balanced correctly. However found that the wobble was caused by the sunnies not locating onto the hubs correctly. I know of two other people removing the wobble in the same way. Borrow a set of standard rims before spending money on bushes and bearings.
LESS YAP YAP, MORE TAP TAP!!
22nd July 2013, 11:08 AM
#74
I had a similar thing happen a few years ago when I had the ft wheel nuts come loose wearing a grove in the hub where the centre hole of the wheel sits, when I put the spare on I got wobble as the wheel could no longer centre on the hub, replaced the hub and the wobble went away,
