19th December 2013, 10:04 AM
Patrol Guru
Seemed like a good idea at the time
19th December 2013 10:04 AM
19th December 2013, 10:08 AM
Legendary
If it goes sub 3 it's still a good buy for some one!
1999 GU 4500 dual fuel
Il dado è tratto
19th December 2013, 10:17 AM
Moderator
if you want a 1800 long Alloy rack then that is a Bargain. bit short for me but a winner for some. I have the 2.1m long one identical and cant fault it.
Check out my Toy -->
Rogue Dung Beetle
19th December 2013, 10:19 AM
They are the powerful 4x4 ones that leak rust onto body work,
but silastic up the holes and away you go
19th December 2013, 11:28 AM
threedogs
Do you mean aluminum rust or what's the go? Are the brackets steel or something?
Hello from Under Down Under!
19th December 2013, 11:31 AM
Enjoying the trips
taslucas
Bloody submit button again.
As for those ones TD is talking about wouldn't sealing the holes hold the water in and cause long term issues?
Better to turn it upside down, fill it with water and block the hole where it leaks, there fore stopping water getting in when right side up on the roof.
Macca
