18th December 2013, 07:30 PM
Advanced
best Breaking Strength kinetic rope for extreme desert stuck recovery
few questions comes across any offroader mind:
Q1-what is the best trusted rope in the market ?
the only stuffs i found at google is:
A-bubba rope : http://www.bubbarope.com/
B-Master Pull rope : http://www.masterpull.com/
(you may know better brands, lets share your experience)
Q2-what is the proper rope rate for your vehicle (computation method) ?
Q3-is the rope will behave negatively with subject to stretch flexibility when the rope rate is too high ?
Y61 SWB 2012 Patrol TB48DE Safari
18th December 2013 07:30 PM
18th December 2013, 07:54 PM
Enjoying the trips
Dynema was an early synthetic to hit the Aussie winch market, it was expensive and paved the way for swags of cheap alternatives.
I bought a 10mm? rope from the states for half dynema's price in 2007 still have it and its working fine. Don't have a clue what brand it is.
It was equal or greater load rating to the steel winch cable I took off, my winch is 9500lb and rope is still in good nick.
Macca
The Following User Says Thank You to macca For This Useful Post:
growler2058 (18th December 2013)
18th December 2013, 09:46 PM
Legendary
Mauz,
I waited and waited for this stuff called X-Line to come back onto the market, as it had the highest strength of all the synthetic ropes, but after waiting three years, I gave up.
I now have SuperMax Rope, as there isn't a whole lot of difference between all the good quality Dyneema / Dynamica Ropes.
Not sure of the brands near you - just get the highest spec you can find with UV Coating to make it last a little longer.
Using a Snatch Block will also ensure that you don't over stress your winch and rope.
I went for the largest / strongest rope I could fit ( 10mm - although the specs said I could use 8mm and still be OK ) .
I did this because as the fibres get dirty and sandy ( of which you may see a little sand from time to time ), it will start to cut into the fibres, making the rope slightly weaker and weaker, and there is a lot of money invested in our trucks, and you want to be sure the rope doesn't break when you are hanging off the side of a hill.
Mic
