Results 1 to 2 of 2
Thread: hub seals
    Dec 2013
    gold coast
    Question hub seals
    can any body help? im trying to fit new hub seals and having trouble fitting them. front hubs with the seal goes on the inside of the disc.haveit got angthing big enough to go around the outside.Thanks
    NT
    I just use a hammer, sometimes a drift (punch with a flat face). It is easy to do, and it is easy to wreck one, too. Just work your way around, gentle taps on the highest bits.
    There are also bearing/seal inserter kits on evil Bay, $35 should get a "kit" *measure your seal first to make sure the kit has a size that will help you. Murphy's law says it will be the only size not included.
