12th December 2013, 10:19 PM
Patrol Guru
1997 RD28T buzzing noise coming from Glow Plug Relay (under the bonnet)
Hey boys,
I had a flat battery in the GQ and took the battery out and charged it using a battery charger for a few days.
I re installed the now charged battery and when I turn on the ignition, there is a very loud buzzing/clicking sound emitting from the Glow Plug relay under the bonnet. Keep turning the key and I hear a solenoid clicking but nothing else. I get dash lights but no glow system lights.
Have I killed the relay or the entire glow system altogether?
Cheers,
Rob
Just about to jump into my next Patrol. A 2001 GU II TB45E .
WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
12th December 2013 10:19 PM
12th December 2013, 11:08 PM
Check the main negative battery cable connection at the engine and body.
The Following User Says Thank You to Yendor For This Useful Post:
rkinsey (13th December 2013)
13th December 2013, 01:29 AM
sure that your battery is still good? I had the same problem in my GQ. glow relay was like a buzzer. I put a new battery in it and the problem was solved.
The Following User Says Thank You to zjuul For This Useful Post:
13th December 2013, 08:07 AM
Patrol Guru
Thanks boys. I had a sneaking suspicion that the battery is cactus.
I'll change it out and see how I go.
Cheers,
Rob
13th December 2013, 10:36 AM
Make sure all pos and neg posts are clean , scourer will help.
after tightened spray with terminal spray to protect.
The Following User Says Thank You to threedogs For This Useful Post:
13th December 2013, 01:44 PM
Patrol Guru
Thanks TD.
Before I fork out $160 odd on a new battery I will reseat the terminal connections after first cleaning them and see how I go.
Will post my findings tomorrow.
Cheers,
Rob
13th December 2013, 01:59 PM
Might even be worth re-doing the earths to the chassis ,body and engine.
This will then eliminate that as a possible cause, as well
