19th December 2013, 11:17 PM
#21
Didn't you run wires using metal conduits recently?
19th December 2013 11:17 PM
19th December 2013, 11:26 PM
#22
You going to need a calm head and start with the basics.
Start at the battery, check and clean the terminals. Hows the main earth lead to the body? the one just under the battery. Didn't you just replace the body mounts? do you have anything earthed to the chassis?
Check fusible links. Check that's the alternator is not overcharging. Check all fuses. From memory there are earth connections in each kick panel, did you reconnect these?.
Have a look at the drivers door connectors just incase they are connected incorrectly, I'm not even sure if that's possible, still worth checking.
It's going to be something simple, go over it in your mind, think about the work you carried out and what possibly could of gone wrong.
The Following 2 Users Say Thank You to Yendor For This Useful Post:
mudnut (19th December 2013), OuchOne (12th May 2022)
20th December 2013, 12:09 AM
#23
Dribble Master
Hey Kallen, can you remember replacing any of the bolts in the cargo floor area, in particular the passenger side? Only reason I ask, is I replaced the Dicky seat bolts and didn't realise they were slightly too long and managed to pinch the cables that run along the top of the chassis between the bolt and the chassis, causing the fuel gauge to read over the full line (when I knew there was only 1/4 tank left. Indicators and hazards wouldn't work and unfortunately I can't remember what else was affected.
megatexture (20th December 2013)
20th December 2013, 12:18 AM
#24
Yendor
You raise a point with body mounts.
All body mounts were replaced.
And I'll start the search tomorrow..
Clunk
Haven't fitted 3rd row, but did remove the 1" body lift so the possibility of a pinch is there for sure..
Ill check that to..
20th December 2013, 08:18 AM
#25
Have checked the main fuses under bonnet with multi meter and all good.
Earth to body is showing 3 ohms (think it's ohms, multimeter set to resistance buzzer).
Currently checking relays under dash and fuses..
20th December 2013, 09:21 AM
#26
Ok.
Have checked key barrel, have connections via different pins in different positions, so I'd say that's working.
Have checked all visible simple relays under bonnet and foot well and all tested good. And all fuses tested good.
Both batteries have charge.
Main showing 8.5v, I know, farked but should show dash lights still
And secondary showing 12.5v.
All wires along chassis look good and free so I think we can rule a pinch out also..
And this is weird. Have opened up drivers side door again and all connections are good, correct and solid..
All other Windows work but the drivers, and central locking only opens when I turn the lights on..
So. Anything.
20th December 2013, 11:39 AM
#27
So I decided to see if I had power at the key barrel plug...
2v... Hmmmm.. Check battery again..
2v..
Ok, battery has shat itself with the 40+ day we had yesterday..
Ill jump it Off the second.. Flick On and ow lights are on...
Ow for fark sake the lights are on!!!:banghead::banghead::banghead::banghead::bang head::banghead::banghead::banghead::banghead::bang head::banghead::banghead::banghead::banghead::bang head::banghead::banghead::banghead::banghead::bang head::banghead::banghead::banghead::banghead::bang head::banghead::banghead::banghead::banghead::bang head::banghead::banghead::banghead:
Bloody night shift, driving home on sunrise and dint turn the lights off when home...
So first up, new crank battery as this one I think is finished. It doesn't hold charge for longer than 3 days..
Would a poor battery be a cause for shotty dash gauges??
20th December 2013, 11:45 AM
#28
Need 12v Kallen wouldn't think 8 volts would help your cause.
great time of year to be lashing out on a main battery, are you
buying one with high CCA. Sealed/ wetcell etc
20th December 2013, 12:45 PM
#29
threedogs
Dunno how I got the 8v the first time. Newbie On the multi... Lol
It's dead. Currently On the charge so I can get it in the drive and pull the dash back out again..
20th December 2013, 02:05 PM
#30
Travelling Podologist
I reckon you should fit a new battery before pulling out the dash again, or at least put the the good (assuming it is good) aux in as the crank battery. At least that way you would be able to take one known quantity out of the equation.
Cuppa
BigRAWesty (20th December 2013)
