Hi I'm mark I'm currently working as an electrician and my patrol is my work vehicle and my play vehicle.
Been a long time reader but first time poster on this forum.
Recently completed a trip to mount walker/lidsdale and had a lot of fun hanging out camping in the area.
Done a couple of trips (cape york-southern highlands) but hoping to get up to fraser in the near future and cape york in the next couple of years.
Currently chasing a front seal issue on the old girl. 2002 Gu Ute Coil Cab 4.2 TD Replaced the Front seal while back when i had the motor out to replace the rear main and clutch(not a fun job) and the front leaked again a few 1000'ks later. Popped my head in at local mechanic for a qoute on getting it replaced by a professional, assuming id cocked it up somehow and was told to check the sump was venting properly...? I guess a pressurized sump would cause you to blow seals not sure how to check its breathing properly other than removing the oil filler cap... maybe someone here knows more about that...
check the operation of the PCV (Pressure Control Valve)(or something ) on top of the rocker cover near the back. about 80mm round and will have a hose coming off it going to your air filter box.
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
Welcome mate, surely the best forum on the net. If you need it, you can get it, if you want to know it, just ask it.
If you want to find it, go to the search bar for a universe of information.
Enjoy the sights and sounds of the greatest show on earth.
