9th December 2013, 11:35 PM
Advanced
Clutch Pedal perfect Adjustment
just changed my clutch disc, cover and bearing at nissan but still feel strange,
wondering if any one have a diagram or factory reference about the gap of the pedal from the bottom
to the engagement point going up ? if i know this info then i don't care how much will remain to the free play up.
on the other hand if any one can correct me if am wrong there is no clutch adjustment in this car right ?
if so how we will know how much is the space between the clutch and the fly wheel with the clutch cover ?
i heard it should be not more than 1 millimeters
what make my clutch age just 35K kilometers ?
how to avoid this again ?
Y61 SWB 2012 Patrol TB48DE Safari
9th December 2013 11:35 PM
10th December 2013, 06:59 AM
i am pretty sure there is no adjustment for the clutch being hydraulic, however i am not sure what kind of clutch you would be running as mine has a dual mass and it went through 2 of those before it did 100,000ks but now i have a solid flywheel and heavy duty clutch and she is sweet cheers.....G millilitres is a measurement of water lol....
2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
10th December 2013, 09:51 AM
Pedal height for yours is 200-210mm and pedal free play is 1-3mm
10th December 2013, 05:17 PM
Advanced
10th December 2013, 05:26 PM
Advanced
threedogs
is that the entire height ?
what i need to know exactly is how much i should travel up with the pedal to make the RPM depressed
