15th November 2014, 09:02 PM
#31
Badball
Hodge, how did you go with the leak? Mine has got worse in the past month, car sat for 2 weeks and emptied the overflow bottle this time.
Hi mate. I think mines not any worse than it was before. I haven't noticed any leaking for a few weeks now. Sometimes I can smell the coolant although cannot see anything from that area. I'm still keeping an eye out on it though. Ever since I've noticed this almost a year ago, coolant level hasn't changed at all. So when mine does leak, it is minimal.
My car was at nissan for a service last week, and I asked them just to have a quick look and they couldn't spot anything. But the bloke did tell me it is common for the 3L Di's to leak from there, behind the timing cover. He hasn't seen any CRD's do it yet, but there is always a first. Knowing my luck it will be mine.
Badball (15th November 2014)
15th November 2014 09:02 PM
19th November 2014, 01:19 PM
#32
Well I bit the bullet, it's in now getting repaired, quoted 8~10hrs plus parts 😳. It was getting worse after every time I drove it.
2005 GU IV 3L ST-S Mods: 3in Zorst, chipped, Autron egt, boost and dual voltage gauges, pillar pod, dual battery, IPF round spoties, Nissan alloy Bullbar.
The Following User Says Thank You to Badball For This Useful Post:
Hodge (19th November 2014)
19th November 2014, 03:42 PM
#33
Badball
Well I bit the bullet, it's in now getting repaired, quoted 8~10hrs plus parts . It was getting worse after every time I drove it.
Let us know what it actually was that was leaking mate.
Sent from my S4 using Forum Runner
11th December 2014, 12:41 AM
#34
I have a leak was behind the plate oil filter. Only noticed when I removed the plate.
20th December 2014, 07:41 PM
#35
Just got home and there is a fark-load of coolant all over the driveway. It wasn't there this morning and the car hasn't been driven. It seems to be coming from the same spot... May indicate that this is getting worse.
20th December 2014, 10:33 PM
#36
Hi Hodge,
The damage was $1800 using genuine parts. The leak was coming from the seal behind the timing gear backing plate that seals against the block I believe. In my case they believe that it was from when the head was replaced it was never sealed correctly or wasn't at all. From what I was told there is 2 ways of doing the head, the cheaper and easy way or the proper way which means removing the timing gear and sandwich plate to ensure that its sealed correctly.
Hodge (21st December 2014)
21st December 2014, 08:51 AM
#37
Mine loses about a litre and stays at that level, temps are ok even on hot days.
No way I can afford $1800 for a fix, so it looks like I just top it up before each trip
21st December 2014, 09:00 AM
#38
I can see where mine is coming from. I just cannot distinguish whether it is behind the timing cover or behind the water pump assembly.
21st December 2014, 03:51 PM
#39
You can now add oil to the mix and coolant is now leaking like a siv. Happy times just before xmas. I think oil confirms that it is the timing cover...
21st December 2014, 04:02 PM
#40
SUCH IS LIFE
Hodge
Shit mate, you're not having a good run hey!!
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
