Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: overdrive 5th gear
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    overdrive 5th gear
    Hi all,
    Has anyone fitted the overdrive 5th gear to their ZD30?
    My coil cab (CRD) has the standard tires (265) and would like to know if gearing the ZD30 for 2000rpm @ 100kph is feasible. Currently it is geared to do 2500ish @ 100kph according to the GPS.
    I do plan to do the usual mods to the engine to fatten up the torque.
    My rationale is for touring and aiming to keep fuel consumption down.
    I'm aware that there are 3 ratios available, just wondering if its worth it.
    cheers
    Ralph
    462 Post(s)
    Hi all,
    cheers
    Ralph
    There is? Where? I would be keen as I have a box here I want to build soon. But it depends on if you tow too. If you do would keep it the way it is.
    Come to think of it. Its a big job to remove the gearbox and strip it down and change the ratio. Would be easier to change the ratios in the diffs I reckon.
    Advanced fxst78's Avatar
    Dec 2013
    South Canberra
    Running at 2000rpm at 100kph will be stressing your motor a lot IMHO, and you may find you actually use more fuel. High rpm does not equate to high fuel use in a diesel. Higher rpm with low EGT versus lower rpm with high EGT, the low rpm is actually burning more fuel and placing more stress on your motor (very simplistic explanation).
    2006 GU IV TD42Ti Wagon. Silver.
    Geelong, VIC
    Quote Originally Posted by fxst78 View Post
    What's an EGT? Sorry got no idea... our patrol is an automatic.
    Sent from my GT-I9305 using Tapatalk 2
    brisbane
    Quote Originally Posted by emm View Post
    Exhaust gas temperature
    I'd love to do my diff ratios to drive 33s like standard but its a bit to much $ for my shallow pockets lol
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    IMO the egt is more important than saving a few litres of fuel. When they go up you have two options, take the foot off the go juice or drop a gear (higher revs). It's important to remember that in certain circumstances the second option isn't enough so you should take take your foot off the accelerator a little to get the temps down.
    There was a great post somewhere that describes how a diesel is different from petrol. The one thing that I think I got right was when you dump more fuel into a diesel it burns hotter (to produce the torque they do), not paying attention can kill your engine.
    I get 100kph at around 2250 rpm so I guess that's the difference between chassis.
    I'm assuming you're not towing ?
    Like it was said before dropping rpm for same speed doesn't always equal better fuel economy (I'm using a scangauge).
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
    462 Post(s)
    Oh! So there is a mod for auto's to add another gear your saying? I have manual sorry im out of ideas.
    Apr 2013
    22 Post(s)
    Hi Mudski,
    Marks Adaptors have the 5th gears, and, according to them, no need to pull gearbox, just drop the transfer case.
  10. #9
    Hi Mudski,
    Any chance of a link ? Thanks
  11. #10
    I think you're going the wrong way by dropping revs at hwy speeds, totally agree with fxst78.
    You might be better off changing diff ratios to suit the larger tyres we run,
    Doing it the other way your peak power will be at 130kph, impractable IMO
    I think those reduced 5th gears are better suited to Duramax or 6.5td conversions.
    maybe even LS1, Going to be peed off if you fit them and not all cracked up as could be.
    Leave the ZD30 alone its fine as it is, no big power machine, As I always say its only 3ltrs
    and highly tuned as is, best spend some money on keeping it efficient.
    Its never going to win any best motor awards, just NADS it and leave it, gearbox and auto included
    unless you want reduction gears
  12. The Following User Says Thank You to threedogs For This Useful Post:
    emm (5th December 2013)
