2nd December 2013, 07:13 PM
Dave's td42ti
My car is a 2006 td42ti wagon.
May as well describe from front to rear!
Factory Nissan winch bar with 12000lb winch, 2" OME and nitro sport shocks, 3" system all the way through running 14psi for around 100rwkw and one of the original powerful4x4 rear bars (highly modded just to get it to work!)
Inside is pretty standard, UHF and pillar pod with boost and EGT gauges.
Plan for the future is a possible turbo and intercooler upgrade.
Will load some pics as soon as I figure out how!
2nd December 2013 07:13 PM
2nd December 2013, 07:15 PM
GQ Snorkle Lockers front n rear
2nd December 2013, 08:08 PM
2nd December 2013, 08:45 PM
Let's see if this works!
The Following 2 Users Say Thank You to fxst78 For This Useful Post:
AB (2nd December 2013), Stropp (3rd December 2013)
2nd December 2013, 08:46 PM
Got it! Only difference is I now have a set of clearview towing mirrors fitted.
3rd December 2013, 02:59 PM
nice clean rig there mate.
3rd December 2013, 04:25 PM
looking good, see powerful call themselves something else now
3rd December 2013, 09:57 PM
Stropp
I can assure you it is not that clean now! This weekend it will be getting a good soak in CT18 and degreaser. Needs a wash and I need to track down an oil leak I discovered this morning. Hope it's not the main seal! If it is I will probably watch it then get it done at 130k and throw a exedy clutch in at the same time.
2006 GU IV TD42Ti Wagon. Silver.
3rd December 2013, 10:00 PM
threedogs
After the rear bar I wouldn't buy anything else from them. It is not bad enough to bother replacing, but if I could turn back time I would have forked out for a Kaymar. I have had to do some work to make it functional.
I have learned that quality well and truly outlasts the initial wallet pain!
3rd December 2013, 10:36 PM
I have a sports range rear bar which is the same as the powerful and I quite happy so far with it, maybe they have upped the quality.
