Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Engine runs on after key is turned off.
    Legendary happygu's Avatar
    Aaron,
    My old 4.2 used to do it every now and again too.
    Never harmed it at all, as it still ran like clockwork when I sold it.
    I would add that it is the fuel solenoid too - If it bothers you too much, then take a look at the wiring first to make sure that the terminations are good, and if there doesn't seem to be a damage or corrosion, then take a look at the solenoid itself.
    Mic
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    I let it idle for 10-15 seconds and it doesn't happen, when I haven't let it idle is when it happens.
    I will give that a go, thanks for the tip.
    Macca
  4. #13
    Expert janderson's Avatar
    Bearii Vic
    3 Post(s)
    Its just that you can't stop a Nissan with a TD4.2. But seriously, mine dose it also. Have given up on finding the coarse. It doesn't do it all the time but when it dose, I just floor the go pedal with the key turned off. Stops strait away then.
    1st G60 Then MQ Now GU
  5. The Following User Says Thank You to janderson For This Useful Post:
    macca (1st December 2013)
  6. #14
    Oct 2013
    North of Brisbane
    This is very common for the 4.2's. The problem is initially caused by lack of maintenance. But once the damage is done there is nothing you can do about it but change the solenoid. If you dont change you fuel filter often enough the fuel pump has to work alot harder to pump fuel and becomes very hot hardening the small piece of rubber on the bottom of the solenoid. This is also the major cause of leaks as the o-rings are affected the same way.
    There is a rare chance the pump is just worn out but there are many other symptoms that go along with that.
  7. The Following User Says Thank You to BauerPower For This Useful Post:
    mudski (3rd December 2013)
  8. #15
    Dec 2013
    Hi MikeBossyBos, sometimes only for a few seconds but sometimes maybe 5 seconds feels like forever and she sounds rough when its happening. she runs beautiful & don't want to hurt her.
  9. #16
    Dec 2013
    thank you every body for your help its been great to hear everyone's thoughts. I have really enjoyed this forum. good crowd. cheers.
  10. #17
    Bearii Vic
    3 Post(s)
    I have noticed that mine seems to run on much more on the hotter days.
