Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Scan gauge 2 or Ultra gauge
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Hi guys,
    New to the forum, (have done intro etc), and have a few questions.
    Firstly, I get that to do any mods on the engine I need to get some gauges fitted, like EGT and boost.
    However, I'd like to fit a scan gauge, and was wondering if there are any major differences between the 2 available options , ie Scangauge 2 and the Ultragauge.
    I'm guessing that they both do similar monitoring tasks and can clear error codes, so is it just a matter of personal preference? or is there a functional reason.
    cheers
    Ralph
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Have not used either but I think its just personal preference, I like the looks of the Ultra Gauge compared 2 the Scan Gauge but I assume they would show the same info.
    Hopefully someone on here has used both and could tell you if there are any major differences, but I doubt there is
    Toddie
    Advanced
    Sydney
    Hi Ralph,
    (copied from another thread)
    I have been running the Ultragauge on my GU7 for the last few years. It reads all available parameters but does not display fault codes.
    If the engine check light comes on you can clear the fault but you can't read the fault code. It can't detect fault codes.
    I like the screen as it is easy to read and configure and also has the option of setting alarms.
    But due to the fact that I can't read the fault code I have now fitted a scangauge 2.
    The display is lacking but at least I know what is triggering the eng check light.
    Advanced
    The latest version of ultra guage can display fault codes.
    See http://www.ultra-gauge.com/ultragaug...uble_codes.htm
  6. #5
    Advanced
    Sydney
    When the ultra gauge was first released it said it would display fault codes but for some reason the GU OBD11 would not communicate this.
    Not sure if the latest release reads the codes on the GU. Can anyone confirm first hand use?
  7. #6
    Apr 2013
    22 Post(s)
    thanks for your replies, much appreciated.
    I have gone the ScanGauge 2, which I will fit up this weekend
  8. #7
    Advanced
    Jul 2013
    HI Guys
    Digging up an old thread here but can someone confirm that the ultragauge will display fault codes for Patrols?
    Supa
  9. #8
    bump
  10. #9
    Legendary happygu's Avatar
    2 Post(s)
    I am after the same info on the Ultragauge too, as it seems pretty useless if it cant tell you the fault codes.....
  11. #10
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    A little while ago I started looking into these as well and came across the EDS engine data scan. Still haven't made up my mind of what model I want to buy though - proabaly doesn't help you too much, but just more food for thought!
    http://www.nissanpatrol.com.au/forum...guage-II/page2
