nice one, I was thinking about doing the same thing, but move the fillers forward rather than rearward.
Looks like you used exhaust pipe?
Yep. Went down to General Mufflers and they bent me up some 2" stainless from memory. Went down to Truck line and bought the flexible fuel filler pipe.
Dead simple and probably one of the best mods I have done. Moving the filler forward should be o/k, the only thing that you have to be careful of is not raising the pipe you move too high if you have to cross them over.
If the pipes are too horizontal the tank that you move the filler is a mongrel to fill if you use a high foaming diesel. Another reason for me using BP as it does not seem to foam up and then I am not sitting there all day trying to fill my sub.
