26th November 2013, 12:06 AM
She's still wobbling
Hi ppl I've read heaps on this forum about patrol wobbles I have recently redone all front end bearings swivel,wheel bearings,seals etc also put brand new tough dog panhard new adjustable drag link new rtc steering dampner new tie rods for the track rod and it still has the wobbles,no where near as bad but it happens around 60-80kmh and sometimes it's worse than other times very frustrated ATM I have noticed there's no balance weights on hrs front wheel could this be the problem?help would be appreciated cheers
Gq patrol lwb 4.2diesel running gt3076 top mount intercooled (with fan) 15psi 4inch springs 2inch body lift slowly adding bits as I go love it
26th November 2013 12:06 AM
26th November 2013, 12:28 AM
Patrol Freak
It can be a problem yes. Get a good balance, it should make a world of difference, its what causes my wobbles
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
26th November 2013, 12:37 AM
Yep it won't take much to put a tyre out of balance, sometimes just mud or sand stuck on the inside of a rim will do it, or a thrown weight.
26th November 2013, 12:40 AM
How is you steering box and radius arm bush's
26th November 2013, 04:27 AM
And to be a pain sometimes the wobbles come from worn bushes in the rear..
26th November 2013, 06:27 AM
Patrol Freak
You can adjust the 'slop' in the steering box, if it has any.
26th November 2013, 08:55 AM
26th November 2013, 09:29 AM
Legendary
1999 GU 4500 dual fuel
Il dado è tratto
26th November 2013, 09:53 AM
Moderator
Wheel balance is the first thing on your list mate.
Check out my Toy -->
Rogue Dung Beetle
26th November 2013, 10:05 AM
Patrol Freak
Make sure you get them balanced by someone that does a lot of 4WD tyres. Some tyre retailers do not have a balance machine that is optimal for wide and heavy 4WD tyres. They are great for normal passenger car tyres but do not balance 4WD tyres properly.
