Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: My soundproofing job on doors.
  1. #31
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    I'll have to look into this flashtac?
    Is it butyl or bitumen based?? I've read most house building items are bitumen based??
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Bitumen.
    This is what a roll looks like (48mm x 10M)
    http://www.ebay.com.au/itm/BEAR-FLAS...31071910675%26
    <a href=http://i83.photobucket.com/albums/j320/02ard/PatrolcomAvatar-1-1.jpg target=_blank>http://i83.photobucket.com/albums/j3...Avatar-1-1.jpg</a>
  4. #33
    Brisbane,QLD
    12 Post(s)
    I should add, I installed flashtac in some car doors in the same method as previously mentioned, i inspected inside the same doors over 13 (yes, thirteen) years later, and it was still sweet, it was a dark coloured car that lived outside 24/7 too !
  5. #34
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Ok, not to stir pots but my question has been answered. It is a bitumen based rubber.
    But also that stuff works out to be $63 ish/m2.
    The butyl mat I bought is $33/m2
    Hell even dynamat works out cheaper if you buy it at $200 for 3,5m2..
    Brisbane,QLD
    12 Post(s)
    Ok, not to stir pots but my question has been answered. It is a bitumen based rubber...
    No probs whatsoever bud
    Flastac is a Bitumen based product with a thin metal backing, i don't know if it has any rubber content, or any more info about the make-up/properties , but i guess you could contact Bear (manufaturer) if you need to know more ?
    Yeh for sure, like i said, i moved on from car audio into home theatre some time ago, (and since moved on to Pro Audio), the principles are still the same, but obviously prices of things have changed.
    Id still concider flashtac myself, as i know it works and have real world tested the product for the application, and coming in strips sure makes installation inside a door cavity easy.
    I encourage people to try new products, thats how i learned and discovered some great stuff, if you can get something cheaper you think will work in your doors, go for it, as long as it waterproof of course !
  7. #36
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by 04OFF View Post
    Yea it's all rubber, Its the compound that changes. They call it bitumen as its similar to the stuff they build roads with.
    It's not actually road with gravel and all..
    It's amazing how much difference this foam makes. I wonder if it will aid or hinder sound??
    Sure Its adding thickness to the pannel but how much is it absorbing
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
    04OFF (29th November 2013)
  9. #37
    Brisbane,QLD
    12 Post(s)
    So your saying i should not re-do my driveway with it then (lol)
    I think you need to look at what each product does, the dynamat type products "block" or stop sound, the foam type products "absorb" or control sound, two different things.
    You can of course obtain good results with foam inside some speaker enclosures, but generally its to make the box "appear" larger to the speaker, the problem is, as i see it, most people put small (6 inch) speakers in car doors, IMO, the standard door enclosure is not sealed properly and so already too big, it almost could be compared to a infinate baffle configuration IMO.
    I would suggest the "last thing" your 6 inch speaker needs, is a huge unsealed enclosure, so "if" foam may make this enclosure appear even bigger, i doubt it will make things sound better, as a big a speaker box can make mechanical damping poor, and the sound may lack some definition, also power handling of the speaker may be less, since the infinite baffle type enclosure provides little control over cone excursion (speaker travel/movement).
    Think of it llike a car engine with no load, it can free rev very easy, but its easy to go past its limits and do damage, a speaker can, over heat, things start clipping, this destroy amps and speakers all in the one go (ive had it happen)
    Just my opinion, every car/speakers are different, so happy to be proved wrong.
  10. The Following User Says Thank You to 04OFF For This Useful Post:
    BigRAWesty (29th November 2013)
  11. #38
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    What you say makes sence. I added quilt stuffing to the rear doors to add depth to my 6x9's but am moving them to the middle doors as the draw system blocks the rear doors.
    The stuffing a good bass line, but with the Windows in the middle doors this ain't an option.
    I'll see how they preform, and the decide if I need extra rubber to seal the door in.
    Im hoping the setup I'm doing helps hold sound in, with the alloy film it should do something..
    So Kallen 2 thumbs up on this product??
    I'll wait till its all back together and you crank up the tunes.
    As 4OFF says its about clear tunes not road noise where ppl get confused
  13. #40
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    I'm going for a quieter ride, not audio.
    I'll expect some audio gain, but I won't be double skinning it..
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    threedogs (30th November 2013)
