Results 1 to 10 of 10
Thread: $1500 to spend on suspension... what to do?
    Apr 2013
    Question $1500 to spend on suspension... what to do?
    Got $1500 to spend on a lift kit for my 99 GU patrol TB45/5 speed. What should I do?
    It is a daily driver, but im not afraid to give it a hiding in the Brindies on weekends too. Its currently riding on a 2" Tough Dog setup with what I can only assume are coil spacers. The current shocks are shagged, but so is pretty much every other bush in the car (hence my $1500 budget cos the rest of my funds are going to fix those). Cheers, Col.
    Feb 2011
    Shed
    45 Post(s)
    OME, TJM or even Dobinso 2" coils and springs and left overs for as many rubbers as you can with the change. Tell them what your going to have in the car weight wise so yiou get springs appropriate for your needs
  4. The Following User Says Thank You to growler2058 For This Useful Post:
    Winnie (11th December 2013)
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    .............yep x2
    Hello from Under Down Under!
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    are you installing yourself? If so I think your options are far greater, tjm wanted to knife me $1600 to install a 2" kit and that was with $300 off! Arb wanted $1900+
    Cheers,
    Eric.
    1998 GU RD28T: RIP
    1996 GQ RD28T: RIP 11 days later
    Hello 2012 GU CRDZD30
    Nissan winchbar + Warn, Dual Battery/Redarc, UHF and Titan rear drawers
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Do it yourself and go OME its what I've just done
    Lucus30's 1999 GU ST TB45E
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    I just went a three inch dobinson coils and armada shocks from superior and so far am very happy, installed myself ( never done before). Great customer service and not bad on price. Got the wagon bolt on coil tower brace aswell and a few other goodies. Have a look at their website.
    GQ Snorkle Lockers front n rear
  9. #7
    Apr 2013
    Yeh, self installing. I'll check em out. Cheers guys.
  10. #8
    Legendary happygu's Avatar
    Make sure that you use the genuine rubber Nissan OEM bushes too, as they last longer, and flex better than the poly bushes
    Mic
  11. #9
    Dec 2013
    Northern NSW
    Have to agree, DIY frees up a couple of hundred for extras like bushes, hire/buy spring compressor. Just replaced stock suspension with 2'' kit from Opposite Lock (Dobinsons stuff), shockies, springs and steering damper - parts only around $1200, fitting quote was around $330
    Gold GU4.2 wagon, 3" Beaudesert Exh, Outback rear bar, LCB side steps, factory bar n winch
  12. #10
    I run EFS 2" and find it a great ride good flex too
