13th December 2013, 07:03 PM
#21
Moderator
trekster
Spoke to the man at the 4wd shop today and confirmed it is not long enough to use, has informed me its within legalities here to have it removed, and with the rear off gives more travel, whereas having the front on or off won't change the travel, it also handles quite well hardly any body roll at all!
Trust me Eric the Patrol fundamentally has No Issue achieving decent travel out of the rear. In fact this is probably its biggest problem! We as a group dream of a front end that will flex and why don't they ??? Because the back flexes So well that the front does not need to and therefore does not! But if you Discourage Rear Flex the front actually has to do something.
You will have very limited flex on the front if you have a front sway bar, removing the front and fitting it to the rear is a far better option. Ol' mate who fitted this is living in the past my friend, his logic is floored and incorrect.
Given the coin you saved on this setup I would encourage you to buy a pair of extended sway bar links for less than $100 and swap it out. It will be a great improvement.
Check out my Toy -->
Rogue Dung Beetle
13th December 2013 07:03 PM
13th December 2013, 07:04 PM
#22
Moderator
I note also that I did not require adjustable panards on my 3" lift on the GUIV. What did you end up doing about caster correction mate? Swap arms with him?
Rogue Dung Beetle
13th December 2013, 09:11 PM
#23
MudRunnerTD
Swapped arms, and the adjustable panhard bars are sitting in my garage as they don't fit mine due to series 1 being different to his series 2/3
Cheers,
Eric.
1998 GU RD28T: RIP
Hello 2012 GU CRDZD30
The Following User Says Thank You to trekster For This Useful Post:
MudRunnerTD (13th December 2013)
17th December 2013, 11:11 PM
#24
Has anyone got any experience with Ironman suspension? Ive been told that ironman pro 2" shocks have 3" of lift if I use the 2" springs with a spacer. Is this right?
I want a 3 inch lift but have a mate who's father is a rep and can supply me a set of 2" springs/shocks for $750. I want a 3" lift but have only around $1000 to spend. I already have castor correction bushes and coil spacers from the (stuffed) tough-dog set up that was in my GU when I bought it.
18th December 2013, 09:00 PM
#25
Ordered extendable rear swaybar links the other night, suits 2-8" of lift lol.
Cheers,
Eric.
1998 GU RD28T: RIP
MudRunnerTD (18th December 2013)
18th December 2013, 09:34 PM
#26
MudRunnerTD
100% agree. this is how my GUIV is setup and it is great! Soo Good in fact i am chasing a GU rear sway bar for the GQ.
so does the gu sway bar fit straight in ?...why GU ?..are they stronger or bigger or something ?...cheers
18th December 2013, 10:23 PM
#27
Moderator
menace 2
Yes the GU sway bar will go in. I have GU diffs under the GQ anyway so happy days.
The GQ and early GU rear sway bars are the same size rod, I think its about 18mm. The later models run a much thicker sway bar, maybe 22 or 23mm providing even more rear restriction. Get the front flexing!!
Rogue Dung Beetle
19th December 2013, 08:47 AM
#28
CERTIFIABLY INSANE
MudRunnerTD
Daz,
What are your thoughts on the sway bar disconnects like you can buy from Superior et al. ? I have been thinking of removing the front sway bar for a while but want to remain roadworthy so the disconnects seem like a good compromise.....
19th December 2013, 09:08 AM
#29
Moderator
Drewboyaus
Daz,
yeah they are a great idea. i have them on the front of the GQ but if you play in the mud they can be a right biatch to re-engage. Mongrel. i have teh superior ones and the tolerance is ridiculously small that its nuts. I gave up and no longer use them, just drive around without the pin now. Granted though the GQ is parked 99% of the time and only goes bush.
Rogue Dung Beetle
19th December 2013, 09:21 AM
#30
I only put the GU sway bars on because I was carrying heavy loads on the roof, otherwise I would keep the GQ ones, if you haven't got a big lift or lots of weight the GU bars would properly be to stiff.
I also don't disconnect the bars off road other than the factory disconnect on the rear.
