Page 7 of 7 FirstFirst ... 567
Results 61 to 70 of 70
Thread: Slow drain, how to solve?
  1. #61
    Ballarat, Vic
    174 Post(s)
    12 hour report...
    Main = 12.85
    Deep cycle = 13
    Do you have a wet starter & an AGM deep cycle?
    I reckon those readings are ok.
    You can double check each of them by connecting a small load . eg. A headlamp globe for say, 15 minutes. Whilst connected you should expect the voltage to drop. After disconnecting the load, let the battery sit for at least 30 minutes & then check the voltage again. If it has come back up to 12.7V+ the battery is good & not the problem.
    Rewiring the gauges to only be powered once the ignition is on seems like a good idea. Very small current drains add up when occurring 24/7.
    Once all that is done & back together, think about buying, borrowing or asking Santa for a clamp meter. They are useful tools to have in your arsenal. Cheap clamp meters available on eBay will be sufficient provided they have a DC current measuring capability ( not all do). With ignition turned off, put clamp meter around one of the battery cables ..... You should get a zero amp reading. Any reading means your search for a phantom drain is not yet over.
    Cuppa
  2. The Following User Says Thank You to Cuppa For This Useful Post:
    AB (29th November 2013)
    My son is auto lek and asking him about wire going to start battery and his answer was "WHY" ,
    My thinking is it would go to ignition as you think , can see why it would need to be live at anytime,
    unless it had recall function
  5. The Following User Says Thank You to threedogs For This Useful Post:
  6. #63
    581 Post(s)
    Crap forgot about this...
    Main: 12.7
    Deep cycle: 13
  7. #64
    So still good to go eh.
  8. #65
    581 Post(s)
    Yeah it might of been a lot slower drain than I thought.
    My car can sit for a fortnight before I start feeling guilty and take it for drive to keep it chugging along.
  9. #66
    581 Post(s)
    Main: 12.7
    Deep cycle: 13
    Same results today. Not sure what's happening now but seems its not as bad as what I thought.
    I won't drive it this week and see how it is come Friday.
    After that ill re wire the pyro and most likely that will fix it.
    Thanks again for everyone's advice.
  10. #67
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Just out of interest - what is your crank battery? Some handle minor discharges a lot better than others when sitting for weeks at a time.
    I go away for 4 weeks of work at a time, and was experiencing flat batteries when coming back. The drain was the stereo and the immobiliser, and even though it was a very minor drain, which if the vehicle was being used regularly wouldn't have made a difference, 4 weeks would see the battery flat.
    I have changed my crank battery recently to an AGM (Optima Blue Top D27, as I had it handy) and am in the process of fitting a BMS to manage my Aux battery (for other reasons), but am looking forward to how it goes handling the minor drain. My reckoning is that it should be fine or at least a whole lot better. The previous battery was an Optima Red Top, which while it is a fantastic crank battery, it had virtually no capacity to handle a constant load, even if minor, over any period of time.
  11. #68
    581 Post(s)
    Sorry Cuppa and Ben, missed this post...
    My cranking is
    N50ZZLMF 600CCA
    • Size (mm) 261x173x225
    • Size Code 10
    • Weight (kg) 19.8
    • CCA 600
    Delivering high cranking power for quick starts. Superior vibration resistance for extra long life.
    • No-Vibe Anchor bonding
    • High perfomance starting power
    • High reserve capacity
    • Maintenance accessible Easyfill vents
    • Sure-grip carry handles and Durable polypropylene cover
    Deep Cycle
    Stowaway (ED5 Replacement)
    • Size (mm) 304x174x225
    • Size Code 12
    • Weight (kg) 21.3
    • CCA 680
    • Amp/HR 95
    Excellent cycling for long operating hours, built to withstand rugged recreational use. The choice for remote operation over extended periods in caravans, motor homes and camper trailers.
    FEATURES
    • Calcium/Calcium Technology
    • Designed purely for Deep Cycle use with Industrial quality design
    • Maintenance Free
  12. #69
    581 Post(s)
    Todays report...
    Crank = 12.6
    Deep cycle = 13
    Seems that the Piranha system is working keeping the drain isolated and seems the drain from cranking so far is very very slow.
    I'm going to have to drive the car this weekend, so after Saturday's report I will re wire the pyro and most likely that will fix the issue anyway.
  13. #70
    Beginner Faisal's Avatar
    Nov 2012
    Tabuk, KSA
    I think this will help to find the issue
    http://www.youtube.com/watch?v=KF1gijj03_0
