Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
Thread: Slow drain, how to solve?
    581 Post(s)
    Ok, electrical nuff nuff speaking!
    I have a slow battery drain somewhere so how do I isolate it to find the problem?
    Could it be the pyro gauge as I did run one of the cables direct to crank battery which I assume is to run the gauge?
    Could it be leaking from there?
    I'm really lost in how to even start looking?
    Cranking has cb, winch, pyro, feed to piranha system, led bar, and then standard nissan factory feeds.
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Take off your negative battery terminal, put a 12v test light (or a 12v bulb on wires) in between the now removed terminal , and the battery terminal, all the power now travels through the bulb, the small current draw will illuminate the bulb a little.
    Now pull your fuses one by one, and watch the bulb, when it goes out after you pull a fuse, you know what curcuit is causing the draw, this should help narrow down the problem for you.
    <a href=http://i83.photobucket.com/albums/j320/02ard/PatrolcomAvatar-1-1.jpg target=_blank>http://i83.photobucket.com/albums/j3...Avatar-1-1.jpg</a>
  4. The Following 4 Users Say Thank You to 04OFF For This Useful Post:
    AB (22nd November 2013), BigRAWesty (22nd November 2013), Drew (23rd November 2013), rottodiver (1st December 2013)
  5. #3
    581 Post(s)
    Quote Originally Posted by 04OFF View Post
    Gold!!!
    And simple to test...lol....Thank you mate!!!
  6. The Following User Says Thank You to AB For This Useful Post:
  7. #4
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Earth cable to earth terminal so when you pull the fuse you break the circuit.
    Your just shorting to the chassis atm..
  8. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    04OFF (22nd November 2013), AB (22nd November 2013)
  9. #5
    581 Post(s)
    Shouldn't do this when I'm drinking..lol
    Same result as above photo
  10. #6
    581 Post(s)
    So this confirms a leak yes?
  11. #7
    Brisbane,QLD
    12 Post(s)
    Exactly.
    If you have a second battery , i would disconnect it, to remove any chance of confusion.
    Then test second battery the same way, while starter battery is disconnected.
  12. #8
    581 Post(s)
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    You'll know what still drawing power so you can stop it
  14. #10
    Brisbane,QLD
    12 Post(s)
    If its that bright, thats a HUGE leak !
    Overnighter by the looks ?
  15. The Following User Says Thank You to 04OFF For This Useful Post:
