22nd November 2013, 08:02 AM
Is there a way to externally identify if the front diff id LSD? I was told by a mechanic who is into Patrols that it may have been, but have no knowledge in this area myself.
Reason: Copy into own post and edited
22nd November 2013 08:02 AM
22nd November 2013, 08:13 PM
Rotaredom
Hi mate,
I have copied your question out of your other thread post and put it on its own.
I have no idea other than it having an LSD sticker on it, but as? As I said in the other thread usually only the rears have LSD.
Maybe you have a factory locker in yours
Hopefully someone with more mechanical knowledge will be able 2 answer this for you.
Toddie
22nd November 2013, 08:14 PM
The 747
Unless it has been retrofitted, then no. Not an option with the Patrol mate.
22nd November 2013, 09:30 PM
Hardcore
Lock your hubs in, jack up one front road wheel off the ground, if you can turn the road wheel thats in the air by hand, you don't have a LSD (or its completely stuffed)
24th November 2013, 08:30 AM
04OFF
Thanks 04OFF, Will do!
1st December 2013, 02:57 AM
Also if you have both wheels off the ground with the hubs locked and spin one an lsd will spin the other in the same direction where an open center will spin the other wheel in the opposite direction.
4th December 2013, 10:18 AM
lsd on the front end would be a pain to drive around town, especially in the wet.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
4th December 2013, 11:39 AM
#8
The 747
Why? Dunno about you but I drive in 2wd around town.
4th December 2013, 11:47 AM
#9
Enjoying the trips
Winnie I think he means if the hubs are locked, you would not want auto hubs if it did have an LSD fitted
Macca
5th December 2013, 12:02 AM
#10
I have a front LSD in mine. I got it from the rear of a pathfinder. It is shimmed up really tight and keeps both fronts turning. Makes high speed dirt driving difficult so I just unlock the hubs
