Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Need some quick help from someone a bit smarterer than me.
  1. #21
    I will make it so the front looks like this so it all sits flush.
    BigRAWesty (21st November 2013)
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    2 Post(s)
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  5. The Following User Says Thank You to Punderhead For This Useful Post:
  6. #23
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Yep, but how do you fill the gaps along side the draws??
    As said father in-law has done his on the front and been that way for 15 years in his 80 series. Still as solid as the day he built it.
    Quality ply, we used chip board screw and pre drilled and counter sunk the holes and it's a solid unit.
    Screw every 100-150 mm along..
    Another little tip, carpet your lid and then screw it down. If you carpet over the screws you'll never get it out in one piece..
    And the liquid gel grip and cheap paint roller is awesome for large areas..
    Nov 2011
    Toowoomba, QLD
    2 Post(s)
    You can put on a false front, and while it may pull off, you still have the other bit of ply yo form a front and stop all your gear falling outImageUploadedByMotorculture1385031193.206238.jpg
  8. #25
    330 Post(s)
    Quote Originally Posted by Punderhead View Post
    This pic is how it should be done. Just screw the drawer front onto the carcass of the drawer from inside and it will never pull off.
    Line the insides of the drawers with Carpet will help your load stay quiet off road. Avoid internal rails as they can catch you load and can be a pain in the arse when opening the drawers when they are full.
    Incorporate a pull out table under the drawers Chris, easy to do and a real winner mate. If you want details I am happy to do a couple of sketches for you bud. Plunder heads second pic is a winner though.
  9. #26
    Thanks for the advice guys!
    Darren I will have a lid on one of the drawers to be used as a table. Kris has it in his GU and I love the idea, no loss of storage space and is easy peasy
  10. #27
    CERTIFIABLY INSANE Drewboyaus's Avatar
    Oct 2011
    Essendon
    Until you're cooking and you need something that's under the lid.
    I have a pull out table that comes out from under my fridge slide. I can cook and access the fridge and the drawer all at once. One of the reasons I like the drawers set up with the fridge mounted low on one side and the drawers lined up on top of one another next to it.
    1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
  11. #28
    I cook on a real table.. Haha. The drawer table would be for quick lunch stops to whip up a sandwich or something
