Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 135
Thread: Tigerz 11
  1. #21
    brisbane
    The only reason I mentioned the steel rack and rust is ive got powerful 4x4 steel rack thats getting a bit of rust now 3 yrs later and i can imagine tigers being of the same quality. weight annoys me also certainly not a one man install.
    My next one will be alloy
    Expert oddkid82's Avatar
    Apr 2013
    I have had one if their winches on my old nav, didn't have a problem with it it worked great, I have got one of the awnings on my patrol now and love it.
    I also use the recover gear and no problems with it.
    I also have the single and double swags, they seem to be a lot better than other good brands. Can't fault them.
    Don't knock it till you try it.
  4. The Following User Says Thank You to oddkid82 For This Useful Post:
    bear3103 (12th November 2013)
  5. #23
    Oct 2011
    melbourne
    Thanks for the input guys. Maybe at this stage might wait until something pops up here, fleabay or gumtree. Have also just noticed on the 4wd supacentre site that roo systems bull bars going for about 890.
  6. #24
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    think I might go and get one on Friday. Suggestion I make is, if buying the cheaper cages, throw bolts / washers / nuts in the bin and replace with stainless first up.
    TB42E manual 1996 GQ 30 year anniversary
    33" maxxi bighorns, 3" EFS & Accessories
  7. The Following User Says Thank You to ozzyboy For This Useful Post:
    04OFF (12th November 2013)
  8. #25
    Advanced bear3103's Avatar
    Apr 2013
    What's the tigerz11 recovery gear like
  9. #26
    461 Post(s)
    A few guys have their winches, and used them and had no issues...
  10. #27
    Expert kind's Avatar
    Nov 2013
    brisbane
    There staps and all the shackles pullies all great its rated to aus standards so there fine I have one of there full kits about $200 on line and then add a heavy duty strap and your set
    1996 GQ 2.8TD 3" straight though, draws and oh so much more
  11. #28
    Thomastown, Melbourne
    6 Post(s)
    I have a Tigerz 11 winch and for the price performs well... I have done many recovery's and including very steep recovery's on big lumpy GU's with no winches installed so my car had to do all the work..
    The one thing is the rope does come off the reel and I would modify the clamp that holds the rope to the drum..
    As for a roof rack I have a steel rack (not sure from where) and its ok but I am looking for an alloy one as it is a lot of weight on the roof.
    The last couple of trips I have taken 60lts of petrol with me and with the weight of the rack it is just too much..
    I hang my rack from the roof in my car port.... I would hate to have to get that off and on any other way.
  12. #29
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by Bloodyaussie View Post
    IThe one thing is the rope does come off the reel and I would modify the clamp that holds the rope to the drum..
    Mine has a screw in the end of the rope, but anyway the screw/clamp is not designed for any load.
    You should never unwind so much rope off the drum to get even close to the end of the rope, i would never go less than about 5-10 windings around the drum, depending on what you are pulling/doing.
  13. #30
    Expert Forced Offroad's Avatar
    Apr 2011
    Logan/Daisy Hill
    That bloke in that tigers clip doesn't work there anymore. He Didn't last long...
    FORCED OFFROAD
    Built by NISSAN Powered by HOLDEN Perfected by ME "hulksta"
    http://www.youtube.com/watch?v=3GX2M...layer_embedded
    http://www.nissanpatrol.com.au/forum...Gq-v8-daul-cab.
