Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: On Board Compressor
    Jan 2013
    Quote Originally Posted by makeitfit View Post
    Brilliant explanation thanks a lot I'm all enthused now and will fit mine this weekend . KIS indeed cheers
    If you like that explanation, I have a circuit and explanation to give a warning if you left your lights on
    http://www.nissanpatrol.com.au/forum...Lights-Warning
  2. The Following User Says Thank You to angelo_f For This Useful Post:
    makeitfit (11th November 2013)
    Jan 2013
    Are you running a tank??
    I am not convinced a tank would be worth the effort. The tank behaves like the cistern in the toilet. In the toilet, a low flow rate of water goes into the cistern and when you press the button, you get a big flow rate for a short period of time. This works great when you only need a small total volume of water. In the case of the tyres, this would be likened to using a cistern interface when filling a swimming pool. For the short duration that it supplies water, it is really negligible.
    In the same way with the tank, if you need a short duration of a high flow rate, a tank is definitely beneficial. However, with the tyres, you have to consider the maximum pressure you are really going to get will be the maximum of what the pressure switch is - in this case, 120psi. My compressor says in specs that it has > 200psi and a flow rate of 71 l/min. There may be a slight improvement in filling all the tyres in that the compressor is still working while moving between tyres, but I don't think it would be much. It may be worth while doing an experiment to see by putting a tank in line and comparing results in filling all four tyres
  5. The Following User Says Thank You to angelo_f For This Useful Post:
    Winnie (11th November 2013)
  6. #23
    Quote Originally Posted by angelo_f View Post
    If all you are doing with the compressor is airing up then there is no need for a tank. If you want to fit air lockers down the track though the tank will be a winner for that. A Tank will also provide you a small burst of air in the event you are trying to reseat a tyre that you have stripped off in a rut (common) or want to run a rattle gun or other air tool or air gun.
    In relation to the "claimed" output of the compressor and the airup time you quote, have you put a stop watch on that? What size tyres?
    I have a pair of tanks under my rear seat that I have on an isolation gate valve and if needed can use for seating a bead. When airing up all I'd does is add volume to the airup and therefore time to pump.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    angelo_f (12th November 2013)
  8. #24
    Jan 2013
    Yes - You have a good point about reseating a tyre. All I am doing is pumping tyre.
  9. #25
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    A quick squirt of WD40 or Easy Start, followed by a flame = a very quick andsimple tyre pop back on the rim
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  10. #26
    Not 'dissing you', mate, but doing that on a fire ban day, could land us a huge fine in this fine country, or worse, start a fire. Would be okay any other time though.
