Results 1 to 10 of 17
Thread: injector pump leaking.
    I have noticed the last few weeks with my gq td42 sitting under the carport is leaking diesel. From what i can see it leaking from under the injector pump. Does the usually mean i'm up for the expensive pump rebuild or can i just to the seal or whatever is causing the leak?
    North brissy
    There are a few seals that can leak that can be replaced while on the car. You can get full seal kits for theses pumps for stuff all.
    581 Post(s)
    Give it a good clean to find out exactly where It's leaking first.
    If It's the top seal then you can replace it without taking pump out, so pray its the top one!
    Have a read of my thread below, happened to me a while back.
    http://www.nissanpatrol.com.au/forum...r-Pump-GQ-TD42
    It's def coming from the bottom of the pump at the front. It's the only place you can see the wetness it's leaving behind.
    North brissy
    There is a plate on the side I think which is pretty close to the bottom the oring can perish on this and leak.
    Kook will hav a close look at it.
  8. #7
    think i found the leak. Pretty sure its the place nissanewby is saying. It looks like its coming from a plate on the driver side of the pump that liiks like a similar shape to a thermostat housing/gasket. Is this just an oring?
  9. #8
    North brissy
    Yeah just an oring the same shape as that plate.
  10. #9
    Oct 2013
    North of Brisbane
    I have piles of spare o-rings for the td pumps. Your can have some if you want them. Im north of brissy. If it helps.
  11. #10
    sweet
    Quote Originally Posted by BauerPower View Post
    would you post. wat o ring will i need.
