31st October 2013, 05:20 PM
Automatic Transmission Band Adjustment
Does anyone know where this brake band adjustment is done ?
I can find details on the RE4R03A like this:
http://www.transgear.co.nz/Transmiss...djustment.html
RL4R01A / RE4R01A / RE4R03A / JR403E
Front band
Tighten 50in lbs back off 2 1/2 turns
But am unsure of where this is done.
Also does anyone know the effects of a little more or a little less in adjustment ?
This image gives some ideas where it is, is it a bolt on the outer casing ? If so where ?
31st October 2013 05:20 PM
31st October 2013, 08:54 PM
A little more will make the gears changes harder and make your bands wear quicker. A little less will make it shift sloppy and hold the gears a bit longer. Also cause more wear
Don't know where the adjuster is
