Results 1 to 2 of 2
Thread: Automatic Transmission Band Adjustment
    Does anyone know where this brake band adjustment is done ?
    I can find details on the RE4R03A like this:
    http://www.transgear.co.nz/Transmiss...djustment.html
    RL4R01A / RE4R01A / RE4R03A / JR403E
    Front band
    Tighten 50in lbs back off 2 1/2 turns
    But am unsure of where this is done.
    Also does anyone know the effects of a little more or a little less in adjustment ?
    This image gives some ideas where it is, is it a bolt on the outer casing ? If so where ?
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    A little more will make the gears changes harder and make your bands wear quicker. A little less will make it shift sloppy and hold the gears a bit longer. Also cause more wear
    Don't know where the adjuster is
