Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Reasons why your 4x4 is Overheating
    581 Post(s)
    Car engines tend to overheat because of lack of antifreeze in the vehicle or because of a thermostat that sticks closed, restricting the coolant from flowing through the motor. Discover the most common reasons for overheating engines with information from a certified master mechanic in this free video on car maintenance and repairs.
  2. The Following User Says Thank You to AB For This Useful Post:
    Port Stephens, NSW
    easiest way to check a thermostat I find is to look for the temperature rating on it and then stick it in a saucepan with a thermometer. While the water is warming up keep an eye on the thermometer and the thermostat and see if it opens at the right temperature. If it doesn't, replace it.
    Perth WA
    61 Post(s)
    Just like this.
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
    Beginner reinaldo's Avatar
    Ellis, ID, USA
    Is it the radiator?
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    Quote Originally Posted by The Dogman View Post
    Just like this.
    Just remember to use an old saucepan or pot or mum will go nuts!!!!
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
    I'm guessing you would be just be eliminating this as a cause for overheating, right? If you have gone to all the trouble to remove the thermostat and more than likely stuffed the gaskets and found this was not the cause would it not be advisable to replace them while you are at it?
    I would have to agree.
    Personally I don't test thermostats, I just replace them.
    Tony
  10. #8
    Beginner robsgq's Avatar
    Rockingham
    Im with Tony just replace and make sure your far is on the right way
    cheers
  11. #9
    Advanced GQ4.2's Avatar
    Warrnambool, VIC
    another few reasons why a engine will overheat is, clogged radiators and also your clutch fan not kicking in
  12. #10
    Whats the best way to test the clutch fan. Should it engage on the highway?
