29th October 2013, 10:31 PM
29th October 2013 10:31 PM
29th October 2013, 10:50 PM
Moderator
TD42 or ZD30 mate?
My GUIV TD42Ti developed this same problem while doing the Madigan Line. Took me 6 months to find the trouble. I had already put the funds aside to rebuild the pump! Lloyd glad I didn't cause it would not have fixed the problem and I would have been shattered!!
Do you have a long range tank? Have you changed anything on the car? How long has it been like this?
Mine turned out to be a stone that worn through the steal fuel line on top of the rear spring tower!! Would never have found it!! I cut the line and replaced it wil a rubber fuel line and a 6month problem was gone!! Happy days.
Air leak for sure mate.
Check out my Toy -->
Rogue Dung Beetle
6th November 2013, 01:07 PM
Hi Harrysnissan
I'm no expert but suggest you check the rubber fuel lines that feeds the fuel filter.
I had a pin hole air leaks in mine and while the impact on mine was not as severe it certainly reduced power and revs and general performance. Replaced all rubber lines and made a new GQ.
Chimo
8th November 2013, 11:54 AM
yup sounds like an air leak, check the lines first and also the injectors are tight with no leaks and no damage to the washers. also the priming pump has a rubber washer and make sure that isnt perished aswell. also check the injectors lines for cracks. Worst case scenario could be the seals on the injector pump. there are also six nuts on the back on the injector pump, make sure they havnt come lose also.
