Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: Dual 12v compressor and air tank upgrade
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by sil3nt_dr3ams View Post
    I might move this thread or could I have the title change by a mod please to , Dual 12v compressor and tank upgrade.
    Title changed mate.
    I say go for it mate, and why because you can.
    I have had a steel air tank out of a M.A.N truck since 2003, still not in the 4b yet, was one of those projects I started and never finished
    X 2 with having a steel tank lying around ,with the promise of fitting it one day,
    Then I have this one , Air on Board say the combo is fine for a locker,
    internal mount only
  4. #13
    brisbane
    Thought you were fitting a air horn with that one, its only 3ltrs I don't think that will do much regarding tyres but a nice compact unit.
  5. #14
    brisbane
    Title changed mate.
    You need to stop moderating for a min and pull your finger out lol
  6. The Following 3 Users Say Thank You to megatexture For This Useful Post:
    BigRAWesty (15th January 2016), NissanGQ4.2 (27th October 2013), Stropp (26th October 2013)
  7. #15
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Title changed mate.
    Thanks mate,
    Out with the factory wiring and solder joints.
    These compressors have a different thread than normal nitto fittings, so out with the tap and die sets.
  8. #16
    Mar 2013
    Second compressor ready,
    Tank in.
    Now the fun starts, where to put the second compressor.
  9. #17
    Mar 2013
    Are they sharing a manifold or one for each.
    one in each 1/4 panel ???
  11. #19
    Thomastown, Melbourne
    6 Post(s)
    What is the braided line you are using mate... I run one of those compressors and it gets so hot it melts the line all the time.. I have made changes 5 times now.
    My other compressor is a TJM one and it gets no where near as hot.
  12. #20
    brisbane
    They look to me to be household plumbing hoses, if they are could be an issue as they are only rated to 90-100 degrees unless they are a specific hose?
