Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Bullbar ripped from chassis
    Expert Trolatron's Avatar
    Jul 2010
    Tassie
    WARNING VERY STRONG SWEARING IN THIS VIDIO.............F F F F ....
    I dont want this to turn into a massive heated debate on whos at fault and should have known better and all that like it did on the forum I found this on but rather it serve as a reminder to all to check your recovery points and condition of the chaise etc.
    Read the guys comments.
    "for those that don't know and quick to judge, go fk yaself, strap was attached to steel rated recovery point bolted to chassis, alloy bar bolted to said bracket, recovery point was ripped from chassis and took bullbar with it, sheered 2 bolts and tore bit chassis out, very lucky no one was in way"
    monaroman37 4 days ago
    2009 ST Wagon
    My very much missed Shorty
    http://www.nissanpatrol.com.au/forum...rolatron/page7
  2. The Following 2 Users Say Thank You to Trolatron For This Useful Post:
    Bloodyaussie (20th September 2015), rusty_nail (17th March 2012)
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Good find mate - no debate here, if you go at it and absolutely everything isn't up to scratch (something wasn't or this is a one in a billion freak incident), then people are put in harms way.
    Lucky lads, glad no one was hurt and always good to remind everyone how pear shaped things can go ...
    Probably didn't need that much of a hit to get him out, but seen it before without any drama (I personally would have done it different, but who's to say how 'stuck' the truck really was ... may have been heaps worse than it looked).
    Feb 2011
    Shed
    45 Post(s)
    Lucky lucky lucky!!!
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Wo! Thats pretty mad!
    Lucas
    Hello from Under Down Under!
    Advanced cokeholic's Avatar
    Greenvale
    very lucky with all the bystanders nobody was hurt
    Only a dog understands why bikers ride bikes
    Jul 2010
    Tassie
    Lucas
    Was down Hobart way....
    2009 ST Wagon
  9. #7
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    Hmmmmm I know MK Patrols pretty well I think. And all I can say is it looks lik too much and I can only guess badly thought recovery points, as MQ/MK are usually right at the front bolted only to the inner side of the chasis as is the bullbar. Recovery points need High tensile bolts all the way through the chasis with a spacer inside to stop chasis squashing in when tightening with the nut.
    Tim
  10. #8
    Quote Originally Posted by Finly Owner View Post
    Tim
    I don't have recovery points on the front o mine yet but I've been told you need to do the same with GQs
    Will have to check this vid out later on the lappy
  11. The Following User Says Thank You to Clunk For This Useful Post:
    Finly Owner (10th March 2012)
  12. #9
    brisbane
    jeez that could have been prity serrious! i think it was stuck prity good even before the bar got ripped off the truck didnt even flintch and looked like he had tried b4 the camera had started and was backing up for more run up.
    all im certain of is if i was there id be swearing like a trooper also !!!
  13. #10
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    Oops. Snatch strap stronger than anchor point - not that they knew that.
    Very lucky.
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
