Page 15 of 15 FirstFirst ... 5131415
Results 141 to 150 of 150
Thread: Sound dampening..
  1. #141
    Patrol Guru paulyg's Avatar
    Ballarat
    I just used the rubber part, so only a slight improvement in noise reduction,
    But I didn't think the GU was to bad anyway.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Interesting reads here. I know this is an old thread, but I'm about to start this process with my 99 GU. Except, the goal is thermal insulation instead of just sound dampening. I know there is some overlap between the 2 goals, but thermal insulation is of the utmost importance here in Siberia when dealing with the winter conditions. Will have to post up some progress pix as I get into it.
  4. The Following 2 Users Say Thank You to SiberianPatrol For This Useful Post:
    BigRAWesty (27th August 2015), Majestic (27th August 2015)
  5. #143
    43 Post(s)
    Quote Originally Posted by SiberianPatrol View Post
    So how did your job finish mate??
    I must say I'm still very happy with my end result.
    And now three the summer the car ac works much better.. you still get heat coming threw when the car is resting in full sun, and viscera with cold, but the temp changes much quicker and holds much better.. instead of having ac flat out once down to temp it's comfortable on nfan speed 2..
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Kimbo63 (19th January 2016)
  7. #144
    Jan 2016
    Arusha, Tanzania
    Hey Westy, I can't get Dynamat over here but there is a company that can do a spray on rubber liner - same as what you would use in the back of a ute - do you think this would work for some sound deadening if used under the carpets?
  8. #145
    43 Post(s)
    It may.. any material stuck to the body is "mass loading" the pannels, it's just how much mass is added.
    I noticed a small difference when I painted my rear 1/4 pannels with the paint on stuff..
    It didn't do as good a job as the dynamat but it did something..
    Its an oldie but a goodie is to stuff some
    acoustic batts inside the rear 1/4 panels.
    You'll be surprised the difference it makes.
    BigRAWesty (16th February 2016)
  11. #147
    Jul 2015
    Siberia
    Westy, sorry I didn't see this until now. Yes the job is finished. I used a product over here called Shumoff - a dense 10mm self-adhesive insulation. Insulated the roof, pillars and sidewalls of the cabin. I didn't do the floor because the GU already had a thick pad and carpet. If it still gets cold, I'll go ahead and do the floor as well. I noticed a definite sound dampening and it so far has held the heat very well in -40C temps. So far I'm very pleased with the results.
  12. The Following User Says Thank You to SiberianPatrol For This Useful Post:
    BigRAWesty (23rd February 2016)
  13. #148
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    hey guys,
    i'll be adding some sound deadener/thermo proof on the weekend. just wanted to ask if you guys have suggestions on what to paint the floor pan with? really want something that will seal the floor pan but not smell on hot day's.
    cheers
  14. #149
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    painter recommended to me use body Schultz. under the car haven't done it yet so cant say how good it is
  15. #150
    Oct 2013
    Cairns
    Yeah i was more talking about coating the inside of the cab/floor pan, im interested in a primer/sealer before i lay the matting.
