29th January 2014, 09:50 PM
#61
did it in my freelander took 2 to 3 tanks and the motor runs quieter helped performance and economy a little to still unsure about the cost of 2 stroke and savings of fuel but having a quieter engine helps
am trying my patrol soon doing some lper km first
29th January 2014 09:50 PM
4th March 2014, 01:33 PM
#62
beed doing this in my freelander mk 1 the bmw motor took 3 to 4 tanks and runs like a dream ever since a lot quieter started this in my gu 3ltr and starting to hear the difference a lot quieter when warm
4th March 2014, 02:53 PM
#63
Ok seeing this has been dug up I'll start putting in Castrol Active 2t from tomorrow.
I use penrite 5/40 so noisy when cold, lets see what happens
5th March 2014, 02:41 PM
#64
Will be interested in your finding TD - I just finished a tank with added injector cleaner in it and found the economy improved quite a bit.
My 99 GU 4.2 is good n rattly so will definitely investigate this
Seemed like a good idea at the time
5th March 2014, 07:22 PM
#65
i use it in mine and find its quieter but no improvement in either fuel or performance but i use it as if its quieter im happy with that and TD i also use penrite. Outboard 2 stroke is no good from what i read it has to be 2t,
The Following User Says Thank You to Stropp For This Useful Post:
threedogs (7th March 2014)
6th March 2014, 10:46 AM
#66
SonOf
Will watch results as well
6th March 2014, 11:57 AM
#67
I started using this last week and can say it's a little quiter more when cold. Fuel economy seems better i recon 100km more out of main tank, using 200:1 but i also cleaned my MAF sensor at the same time which was quite dirty so this is probably helping aswell. After reading this im not sure whether to use it in my 08 CRD though, Thoughts?
2008 GU6 ST 3.0 CRD Auto, 2" Lift, ARB Bullbar, IPF Spotties, Side Steps, Maxxis 980 A/T, Roof Rack.....................
6th March 2014, 12:21 PM
#68
I've heard different reports On crd's.
Something along the lines of an inbuilt water sensors On the Fuel system doesn't like it??
Now I have no idea of ratios used when issues happen..
The question which turned me off was,
If this additive giving me the efficiency to outweigh the extra cost into each tank.
For me it wasn't..
7th March 2014, 10:09 AM
#69
I wasn't really to concerned on fuel savings although it would be a bonus but more for the lubrication benefits which if it does would definitley outweigh the extra cost.
In saying that i think im going to stop using it until i can get more information about using it with the crd's
7th March 2014, 10:25 AM
#70
How do you guys reckon this would go in the Chevs?
2006 Ser IV GU, 6.5l TD V8 Chev with 4spd Auto, 3in Lift, 35in Kumho's, 12000lb winch, Nissan snorkel, Diff breathers, lightbar + Lightforce HD spots on roofrack. Built to go bush.
