Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 151 to 160 of 170
Thread: DIESEL FUEL + 2T OIL = Superb performance?
  1. #151
    Jan 2018
    I run this.
    Perfect. I have a Caltex down the road. I heard that one or the Gulf Western one is good as its dirt cheap too
    Expert Daveyboyjunior's Avatar
    Feb 2015
    Dartmoor, England
    Added the Comma equivalent to mine today. 125ml to half a tank as an experiment.
    The difference it made to the tone of the engine was very noticeable. Within a few kilometres of the new fuel and 2 stroke going in, the top end was less clacky and rattle free. Smooth through all the gear ranges.
    Amazing!!
  4. The Following User Says Thank You to Daveyboyjunior For This Useful Post:
    Hodge (10th April 2018)
  5. #153
    Jan 2018
    Quote Originally Posted by Daveyboyjunior View Post
    Amazing!!
    Thats insane. Idle quieter too?
  6. #154
    Feb 2015
    Dartmoor, England
    Funny enough, the idle has always been as I might have expected, but even idle has been slightly muffled by the newly added two stroke lube!
    It sounds like all the moving parts are now getting some proper goodness!
  7. The Following User Says Thank You to Daveyboyjunior For This Useful Post:
    drgtr (13th April 2018)
  8. #155
    Uuummmm... the 2T is in the fuel so it only affects (or lubricates) 3 things;
    Fuel Pump
    Injectors
    Upper Cyl
    The main component of those that the 2T will reduce is the mechanical Injector rattle.
    If enough 2T is getting to affect other 'moving parts' then you have serious problems in your oil feed
  9. #156
    Feb 2015
    Dartmoor, England
    Fuel Pump
    Injectors
    Upper Cyl
    Thats why she's running quieter!
    My oil feed is just fine. Happy days!
  10. #157
    Jan 2018
    Thats it. Im gonna get some gulf western or the castrol activ tomorrow morning and chuck in 450ml in main and 150ml in sub when I fill up.
    Its gotta be good for the pump and injectors
  11. #158
    Feb 2015
    Dartmoor, England
    Quote Originally Posted by drgtr View Post
    What's the capacity of your tanks? Get the ratio right.
  12. #159
    Jan 2018
    Factory so 95 and 30 ?
    200:1 or times tank litres by 5?
  13. #160
    175 Post(s)
    I've been putting in 250 mL for an entire fill. And still makes a considerable difference. So I just add the 250ml to the main tank, than fill both tanks and gradually fill the main from the sub as the main goes down.
    So thats 250mL per 125L, each time I fill from empty.
    Important thing to remember is, this works good when filling from empty.
    Some people fill up when their tanks are half or quarter full or whatever... If you do it this way and add 2T each time, the 2T ratio to diesel might rise. Hope that makes sense.
  14. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Daveyboyjunior (14th April 2018), drgtr (14th April 2018)
