Well, today was good.
Went to Pro 4x4 and bought recovery points to replace the HOOK.
Quotes for the EGT/Boost gauges and snorkel.. Now to see what the Department of Finance says...
AJTich
2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector... "I don't get bogged, I have unplanned 4WD training activities..."
a. Two small cracks at LHS and RHS Radiator bracket: Possible front on hit? Only small but need welding;
b. Small crack front RHS inner guard... ?;
c. Modification to front chassis?? ;
d. Both Gearbox mounts torn;
e. Rear anti-roll bar joints/bushes worn/worn out;
f. Front axle LHS mounting arm centre bush torn, L and R front bushes worn;
g. Driver's seatbelt cut...
It is 9 years old, so guess it has had a previous life...
Now to check whether Dealer will do what is required.. If not then I name/shame, and possibly sit at their shop for a day telling ppl not to buy from the shonks.. LOL
AJTich
Got Matt from Extreme Automotive and Marine Installations (Home of 12Volt) to fit my Auxiliary Battery ... Nice job, neat, strong...
Pirhanna battery box, but cut off the top fitting, and ended up needing to fit different Marine Grade tie downs. Strong... Geez I don't plan to tip it over but sure it will stay put..
I've run a 20 Amp Anderson Plug to front and rear, and the twin Merit setup in the back for fridge, etc...
Also modded my 12 Vdc compressor to Anderson Plug, and used the cutoff 12V Pos/Neg, some lead and another Anderson Plug in case I need to run onto a battery.
AJTich
Well, try again...
'Work is something that takes me away too often.
Since the last post have been out bush a few times, and manged some more mods...
Although late, here is an abridged review of mods and additions..
Bought a camper trailer: Liberty 14.
Mud and sand at Morgan Quarrie and over the river... 2014-05-18 15.37.24.jpg
Went to OTT...well the one near Wilpena Pound... so many great tracks... DSCN0769A.jpg
Peake... I don't get bogged, I have unplanned 4WD Training activities... DSCF3252A.jpg
AJTich
Thanks for sharing the pics, You said you went to Morgan quarrie, was that with a 4wd club?
Yep. Part of 4wd SA training last year... am in 4wd Adventurers now.
AJTich
