Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Hf Radio install
    With the rear wheel carrier off you can fit some flat plate on the door and follow contour till clear of the wheel as GQT states
    if you cant fold or bend to shape you want use a 4" grinder and cut half way through bend and tack weld till shape is perfect.
    Allow for when door is open, then weld up cut. Spray paint or powder coat, leaving some bare metal to earth on.
    Patrol Guru
    Apr 2011
    Melton
    Our installers make a plate as per threedogs description.
    We found that earthing to the door, did not provided a good enough earth.
    We ground our HF antennas to one of the door hinge mounting bolt (body side), using a heavy braid.
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
  4. #13
    May 2012
    Whyalla SA
    bulbar mounting will only get you a ticket.
    Is this a state thing or Australia wide?
    Just ask as I have recently seen a few 4x4s with the HF aerial mounted on the bulbar, same place as most mount their UHF aerials. This is here in Adelaide.
  5. #14
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    It is australia wide, basically only time it's permitted is if there is no other suitable mounting options
    www.swat4x4.com
  6. #15
    Patrol Guru
    Apr 2011
    Melton
    I thought the main reason why mounting a Codan Auto tune on the front of a truck is illegal, is due to the size of the autotune unit.
    I have seen a bracket that bolted to a towbar
    The other consideration is the HF getting into the vehicle eltronics.
    Also ensure no one is within 1 meter of the antenna when you are transmitting - RADHAZ.
  7. #16
    May 2012
    Whyalla SA
    I thought I read somewhere that the latest Codan's latest whip auto tune, 3040 was legal in Australia for bull bar mounting.
    I have not chased them up on this yet as I am still tossing between HF or satellite phone or running both.
    I see benefits in having both but the combined cost is not enticing. Not to mention where in the heck do you place a HF unit in a GU IV. GQ fine but the GU is a pain even for UHF. Though got the UHF solved and glow plug timer location solved.
  8. #17
    W.A. (wandering aust)
    Front mount autotuners are OK if there are no other "suitable" options AND the max dia of the unit is <75mm AND the mounting method passes the ADR pedestrian friendly test.
  9. #18
    Expert janderson's Avatar
    Bearii Vic
    3 Post(s)
    Quote Originally Posted by outback View Post
    this is for Vic but prob for other states also
    Attached Files Attached Files
    1st G60 Then MQ Now GU
