With the rear wheel carrier off you can fit some flat plate on the door and follow contour till clear of the wheel as GQT states
if you cant fold or bend to shape you want use a 4" grinder and cut half way through bend and tack weld till shape is perfect.
Allow for when door is open, then weld up cut. Spray paint or powder coat, leaving some bare metal to earth on.
Is this a state thing or Australia wide?
Just ask as I have recently seen a few 4x4s with the HF aerial mounted on the bulbar, same place as most mount their UHF aerials. This is here in Adelaide.
I thought I read somewhere that the latest Codan's latest whip auto tune, 3040 was legal in Australia for bull bar mounting.
I have not chased them up on this yet as I am still tossing between HF or satellite phone or running both.
I see benefits in having both but the combined cost is not enticing. Not to mention where in the heck do you place a HF unit in a GU IV. GQ fine but the GU is a pain even for UHF. Though got the UHF solved and glow plug timer location solved.
Front mount autotuners are OK if there are no other "suitable" options AND the max dia of the unit is <75mm AND the mounting method passes the ADR pedestrian friendly test.
