Results 1 to 5 of 5
Thread: Installed my Provent oil catch can today GQ RD28
    Advanced ashleylipus's Avatar
    Mill Park, Melbourne, VIC
    finally installed my provent oil catch can today on my 2.8 GQ after its been sitting in my garage for months..
    i bought some 1'' to 5/8 silicone reducers from ebay. quite cheap!
    http://www.ebay.com.au/itm/AeroFlow-...291132c&_uhb=1
    16mm barb fittings
    http://www.ebay.com.au/itm/Brass-Fit...d4e6246&_uhb=1
    and i found cheap teflon braided hose
    http://www.ebay.com.au/itm/281111081...84.m1439.l2649
    now i just need to run some clear tube at the bottom with a brass tap at the end and place it somewhere accessible for emptying..
    very happy with the result..
    i will take note of the kilometres and check how much oil has been filtered after 1000 klms and put another post here..
    Aug 2010
    adelaide
    i used a plastic garden tap for sprinkler systems
    this is in the pasanger front wheel arch
    OH LEATHER IS NICE
  4. The Following 2 Users Say Thank You to my third 256 For This Useful Post:
    ashleylipus (7th October 2013), ova50 (12th December 2013)
    Quote Originally Posted by my third 256 View Post
    Great idea thanks!!
    Sent from my iPad using Tapatalk HD
    Oct 2016
    Quote Originally Posted by ashleylipus View Post
    How have you found this catch can setup over the long run? Stood the test of time? How much filtration?
    194 Post(s)
    Quote Originally Posted by Crimpy View Post
    I had this exact system on my 2.8 and it cleaned up all the oil muck that was getting into the intercooler. I started with exactly the same tap, but found it didn't seem to work with the tap closed. I removed the tap, hence an open pipe, and bingo - but what a mess! The oil mist and drips ended up blowing onto the chassis rails and picked up the dirt - total pigstye. I don't have that system anymore as have changed motors, but think if you are able to direct the oil below the chassis then the mess will disappear.
