6th October 2013, 06:31 PM
Installed my Provent oil catch can today GQ RD28
finally installed my provent oil catch can today on my 2.8 GQ after its been sitting in my garage for months..
i bought some 1'' to 5/8 silicone reducers from ebay. quite cheap!
http://www.ebay.com.au/itm/AeroFlow-...291132c&_uhb=1
16mm barb fittings
http://www.ebay.com.au/itm/Brass-Fit...d4e6246&_uhb=1
and i found cheap teflon braided hose
http://www.ebay.com.au/itm/281111081...84.m1439.l2649
now i just need to run some clear tube at the bottom with a brass tap at the end and place it somewhere accessible for emptying..
very happy with the result..
i will take note of the kilometres and check how much oil has been filtered after 1000 klms and put another post here..
6th October 2013 06:31 PM
6th October 2013, 08:46 PM
i used a plastic garden tap for sprinkler systems
this is in the pasanger front wheel arch
OH LEATHER IS NICE
The Following 2 Users Say Thank You to my third 256 For This Useful Post:
ashleylipus (7th October 2013), ova50 (12th December 2013)
7th October 2013, 10:44 PM
my third 256
Great idea thanks!!
Sent from my iPad using Tapatalk HD
12th October 2016, 05:25 PM
ashleylipus
How have you found this catch can setup over the long run? Stood the test of time? How much filtration?
12th October 2016, 06:38 PM
Crimpy
I had this exact system on my 2.8 and it cleaned up all the oil muck that was getting into the intercooler. I started with exactly the same tap, but found it didn't seem to work with the tap closed. I removed the tap, hence an open pipe, and bingo - but what a mess! The oil mist and drips ended up blowing onto the chassis rails and picked up the dirt - total pigstye. I don't have that system anymore as have changed motors, but think if you are able to direct the oil below the chassis then the mess will disappear.
