28th September 2013, 12:51 PM
Engine Light - MAF, Oxygen Sensor or Cat?
Good Morning,
So I'm having problems with my 2007 TB48 GU. The engine light is on and after taking it to Nissan they tell me it could be any of the above problems. Now I get that it could be the MAF (I've now replaced and its still on) or any of the four oxygen sensors (I've replaced the two upper ones so far), but how could it possibly be the cat which is half way down the exhaust? There are no sensors past that point so how could it be throwing a code?
The fuel economy, if you could call it that, has just gone from bad to absolutely shocking so if there is some Guru that can maybe clarify my Cat question I would be very grateful.
Thanks Mick
2007 GU ST-S 4.8 Patrol.
40mm heavy duty springs, Dual batteries,
140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
28th September 2013 12:51 PM
28th September 2013, 01:27 PM
Gday Mick, im thinking the only way it could be the CAT is if its blocked up and perhaps pressurising the exhaust up to the oxygen sensor?? That would also make fuel economy worse.
Completely guessing though mate, hopefully someone with some more knowledge comes along soon
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
Skitzyrex (28th September 2013)
29th September 2013, 10:51 AM
Legendary
try cleaning the maf sensor this can cause shithouse fuel economy have a look at this link
http://www.nissanpatrol.com.au/forum...ng-MAF-sensors
2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
OH LEATHER IS NICE
29th September 2013, 12:01 PM
taslucas
Can now confirm that's no longer a problem if it was before. Should the light just go off if it was the problem? Or does Nissan have to reset it again?
29th September 2013, 12:02 PM
my third 256
Cheers mate, I've replaced the maf with a brand new genuine unit the other day after previously cleaning it with no luck.
30th September 2013, 08:17 AM
Legendary
disconect battery for a few hours then should be ok
OH LEATHER IS NICE
The Following User Says Thank You to my third 256 For This Useful Post:
Bob (30th September 2013)
4th October 2013, 10:23 PM
My scanner came today and it through code p0113 which is the air intake sensor. Now by all accounts on my model this is in the maf sensor which for me is brand new.
I have reset the code and it came back within a few seconds.
Any other ideas?
5th October 2013, 05:45 AM
Don't Australian TB48s have more than one cat? that's why the 4 O2 sensors.
I saw a picture that showed 2 very small cats in the downpipes from the manifold, 2 O2 sensors before and 2 after. If I can find the picture I will post, with a copy of my setup (Gulf Spec = 2 O2 sensors).
I recently replaced my complete exhaust with headers and a drainpipe ( sounds like) - I occasionally get the engine light to come on when the engine's cold. It goes out after 5 - 10 mins.
Cold here is a relative term It seems hot to me, but obviously the engine is cold enough to engage the cold start system and enrich the fuel supply.
Steve
2011 Patrol Safari 4.8 (Fitek)
5th October 2013, 09:51 PM
Bulbous
Yes mate, I now know it has 3 cats. The oxy sensor code though is no longer coming up after replacing the sensors.
19th March 2024, 09:29 AM
Hi, just wondering if you found the fix for your TB48 fault from years back? I've got a similar fault on mine and was wondering what the eventual fix was on yours. Cheers.
